hi
i have setup a 5 star resort with 600 rooms and i have big problems with the fiber connection between the devices
the devices that i have in the network is
- CCR1016-12S-1S+ working as hotspot server with radius server and as capsman server
- 35 Sxt G-2HND
- 15 RB951Ui-2HND
- 9 CRS226-24G-2S+
- 5 CRS210-8G-2S+
- 10 SFP MODULES S-85DLC05D
- 10 SFP+ MODULES S+85DLC03D
i have the connected with fiber
suddenly i lose connection between the crs and the ccr and if i connect to crs that i can see with winbox i can see that the sfp link is running but i have no packets request from the other crs (i have tested either with auto negotiation on or off) if then i go to the next crs that i cannot see from the previous and make a restart all works ok for 1-2 hours and then the same again happens after i had this done in 1 day 12 times i have connect the crs between them with Ethernet cable all
is ok to this 2 crs that i have connect with cable and the problem goes to the next 2 crs that is connected with fiber
P.S i use 6.27 ros but i have tested and 6.28, 6.29rc,6.26
any suggestion what the problem is because all this makes me crazy
