I have symetric 100 Mbps WAN connected to CRS226-24G-2S+ v 6.30 and under speed test (from laptop on speedtest.net) I have only 28 Mbps throughput !
I’ve checked without CRS and WAN is full speed 100 Mbps.
I have only one NAT rule:
[bertj@R1_CRS] > ip firewall nat pr
0 chain=srcnat action=masquerade to-addresses=0.0.0.0 dst-address=!10.9.22.0/24 out-interface=ether3-WAN log=no log-prefix=""
[bertj@R1_CRS] >
Under test the CPU usage is about 90 %.
There is no queue configured.
What do I wrong ??
Is there any possibility to do this better, or only must have to buy CCR?
When running the tests, open up a tools → profile before doing so. It will tell you which process is using the CPU.
I do agree with the statement that if you are only seeing 38% load, your problem is not CPU load and thus in theory you should be seeing much higher throughput.
Are all the ports you are testing through correctly connected at 1Gbps?
