CRS305-1G-4S+IN LFP/LLP transparent sfp signal mode,Link loss forwarding
Hello
Is it “link loss forwarding” supported on ros/swos?
Is there maybe any other similar feauture ( i.e. like BFD over ethernet) which could do the same thing?
for example:
LAN1—CRS305#1-----layer2_NETWORK—CRS305#2— LAN2
some feature which could detect failure somewhere in a layer2 network between CRS305#1 and CRS305#2 and
then bring down ports toward LAN1 and LAN2.
If not is it possible to foward LACP mesagge transparently between LAN1 and LAN2 devices?
I will use CRS305’ to repeat a wave that required more than 80 km laser.
Thanks in advance
LACP forwarding:
http://forum.mikrotik.com/t/forward-lacp-in-bridge/122451/1
For no lacp links workaround:
I use a tagged vlans on bridge and set dummy ip on ends, setup netwatch to shutdown the port if ping fails…
Workaround for only one crs305 regenerating signal :
On switch’s connected to the crs305 use lacp eaven if you have only one link..
