Hello!
I recently purchased a CRS305-1G-4S+IN, got it hooked up, and started having some issues. First I connected, updated the RouterOS software, then tried to change it over to the SwOS. I could then no longer connect to the switch, either through the IP (I found it on my routers DHCP list), or the WinBox software. It doesn’t even show up anymore in the Neighbors tab. I have to reset the switch to get it to show up again, at which point of course its in RouterOS mode again. The switch still works however, passing along data as normal, the command interface is just not reachable.
So far I have tried on both firmware 6.45.9 and the updated 4.48.4, changing the boot protocol to dhcp, only connecting directly to the computer with no other connections, and booting in safe mode.
I am trying to troubleshoot why I’m not getting 10Gbps between my server and my main machine, but I think it may be the cable for that issue.
What am I doing wrong?
