Hi All,
I’ve gotten pretty far on my own trying to figure this out but I seem to be at an impasse. I have also looked through the forum and found some cases that were somewhat similar but not quite the same (as most of those were dealing with 1G internet speeds and had different setups and situations).
Here’s my current setup/situation:
I have a Mikrotik CRS309-1G-8S+IN switch. I currently have a 100’ long, 5 Gbps Cat8 ethernet cable (also tried Cat6 and Cat7) from a Google Fiber router (which is confirmed outputting 5 Gbps) to SFP port 1 on the switch via an Ipolex ASF-10G-T 10GBase-T RJ-45 30-m ethernet to SFP+ transceiver.
Then I have my computer plugged into SFP port 3 on the switch via an SFP+ fiber optic 10GBase cable. That SFP+ fiber optic cable goes from the switch into a QNAP QNA-T310G1S Thunderbolt 3 to 10GbE Adaptor, which then plugs into my computer via the thunderbolt USB-C port (eJS45 [ethernet] port is limited to 2.5 Gbps).
At first, on my computer, I was getting about 4,850 mbps (wow) download but I was only getting around 500 mbps on the upload (all tests performed with speedtest.net, which is what google fiber recomended). Via WinBox>Quick Set, I updated the router OS on the CRS309-1G-8S+IN to the latest “Stable” version (7.11.2) and that got me up to 2.5 Gbps on the upload but the download has now also dropped to 2.5 Gbps. It should be showing around 4,850 mbps download AND 4,850 mbps on the upload - which is what I get when I connect directly to the router and don’t go through the CRS309. I then tried updating to the latest “Testing” version (7.12rc4) of the OS but that didn’t seem to affect internet speed.
I have tried plugging the computer and incoming internet signal via ethernet cable into different ports on the switch but that didn’t seem to change anything. Granted: I didn’t try every single port.
Any ideas what could be causing the 2.5Gbps cap? I know that it can download at 5Gbps because it was doing that speed before I updated the switch software/firmware. That indicates (to me) that it is not a hardware issue but instead, is something to do with the OS/firmware or settings.
PS. I am not an IT person or programmer or anything like that. I’m not very familiar with terminology for this stuff but I am slowly learning as I troubleshoot this. Just trying to allow the full internet speed through this router.
Any ideas on what could be happening?
