DISCLAIMER: I could have been VERY unlucky, and/or overzealous about checking my hardware on arrival, so please read this with the disclaimer that I only have had less than 15 of these in my hands. But to my defense, I see others with my problem.
Now, I love Mikrotik switches, and I have never had any issues other than 1 failing out of hundreds, but the CRS310-8G+2S+IN model probably need a recall.
There are two main cooling blocks glued to two chips, and the left-most block is failing (labelled “U1”), it simply falls off and sticks to whatever it lands on. Normally you won’t notice this if the block doesn’t short anything out or the unit gets too hut, which is what alerted me to this issue. The most common scenario, is that it sticks to the chassis.
I had an order of 10 where one suddenly overheated, and I took it apart, it was pretty obvious why it overheated. So I RMA’ed the ones that had the issue and it took months for Mikrotik to acknowledge the fault. I then got another shipment with the exact same issue on 50% of them.
The supplier couldn’t promise me that they wouldn’t send from the same batch and they wouldn’t check them before shipment, so we gave up on them and ordered from another supplier in another country (DE → DK) to hopefully not run into the same batch.
And now the exact same thing happened again, 50% of the order was broken (I only dared order 2, so 1 was broken).
I suspect this could have happened by the units have been exposed to extreme heat while sitting upright i a storage somewhere, and due to heat pattern, one got so hot that the glue gave out, and it fell to the left (I always see them on the left side if they are sticking to something).
So riddle me this, if I need 20 of those switches, how many times will I have to order and RMA the units before I end up with 20 good ones? It’s an interesting math problem that fits well in a public school test
Please Mikrotik, we need you to look into this.
To everyone else, if you are afraid you have this issue, remove the 3 screws from the casing and check if the cooling blocks are in place, I’ll bet you that in 50% of the cases they are rattling around in there, or are stuck to the chassis.
Regards
/Allan
