After the last update of today my CRS310 is not booting anymore.
Alternate bootloader seems not to work as well.
No network connectivity, all SFPs stay quiet
Fan 100% forever
Fan 100% forever
Try to boot with reset pressed before plug the power, and after 2 sec release reset (load backup booter)
If fail, netinstall with option "keep previous config" (but the "files" contents are lost)
Thanks netinstall did it
I also experienced the same thing on my cr310 router. Not detected with netinstall, do you have a solution?
