Hi all gurus!
My CRS312 is setup but I am having super slow transfer speed across 10GBE lan devices.
We have 3 workstations running 10GBE & 1 QNAP that supports 10GBE. I am only getting a 50mbps - 100mbps per transfer over 10GBE.
Any ideas?
Regards from the land of Arizona!
Shy
July 11, 2020, 6:06am
2
Could you export the config hide sensitive data?
Sent from my SM-A705FN using Tapatalk
jul/15/2020 22:46:00 by RouterOS 6.47
software id = 8AUA-YJN6
model = CRS312-4C+8XG
serial number = -
add name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-f
ull,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full"
/ip hotspot profile
add name=dhcp_pool0 ranges=10.10.10.2-10.10.10.254
add name=dhcp_pool1 ranges=123.123.123.2-123.123.123.254
DHCP server can not run on slave interface!
add address-pool=dhcp_pool0 disabled=no interface=ether2 name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp2
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=combo1
add bridge=bridge1 interface=combo2
add bridge=bridge1 interface=combo3
add bridge=bridge1 interface=combo4
add address=10.10.10.1/24 interface=ether2 network=10.10.10.0
add address=123.123.123.1/24 interface=bridge1 network=123.123.123.0
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
add address=123.123.123.251 client-id=1:24:5e:be:44:4e:f5 mac-address=
24:5E:BE:44:4E:F5 server=dhcp2
add address=123.123.123.0/24 gateway=123.123.123.1
/system clock
set time-zone-name=
/system routerboard settings
set boot-os=router-os
I am also facing internet issues.
My true internet speed 900 up 800 down
If I am connected to the mikrotik, I only get 300 up and down.
I tried fasttracking but so far no avail.
