Would anyone know where on the board the NAND chip is for the CRS317 and what make/model/type it is?
I need to look are replacing it due to bad blocks even with a very low total write count. Unfortunately, the device is a number of years old and wouldn’t qualify for a warranty replacement.
I need to reboot the device after a while to be able to take a backup etc.
The license price is not low either, ROS level 6 (icluded with CRS317) MSRP is $250 (you can get it cheaper from some resellers) which might add to the cost of repair.
MT’s own help page suggests one to contact their support before doing anything potentially destructive to device. So why don’t you send an email to support@mikrotik.com describing what you’re after and see what they’ve got to say? They might help you with license migration if they deem your actions acceptable …
I did reach out to Mikrotik and they said in a nutshell, they couldn’t help and I would lose the license if I replaced the NAND. They said I would need to purchase a new one.
The device logs 0 to disk, and only keeps the odd backup we save to it in case of an emergency restore. I suspect this device had a bad NAND from day one, and it’s only something, since I obtained the device, put any time in to investigate. I will give the netinstall a bash as I don’t think I did do it to this switch…
Here is a comparison of 2 switches purchased together. Look at the difference in writes vs %bad blocks.
Don’t recall what file system MT is using for NAND’s in v6 but it might be worth trying to reformat it using Netinstall and if you are lucky all faulty blocks will be added to the “bad block list” on the drive.
Yet another reason 16mb of flash is such a bad design choice
in v7 with the bundled package, there are about 2mb of flash free on the device for wear leveling to work on
most of our switches in v6 had about 8.4mb free due to not having Wireless/Hotspot/etc packages loaded.
but v7 takes that workaround away, so i expect to see a higher churn rate of equipment in the future.
as a last measure before you throw out your CRS and after you have tried Netinstall:
There is a way to save & successfully reinstall your license key. This procedure works for some RB models, and it was documented as a way of going back from an OpenWRT install to ROS. It might work for your device as well, but there is of course no guarantee: https://openwrt.org/toh/mikrotik/common
There are some companies specialized in replacing chips on devices. They mostly do console or mobile phone repairs, but I would ask one, if they are capable of creating a binary dump from the old chip, then let them write it to the new chip.
Awesome, yeah the plan was to get an electronics repair company to replace the chip as they have the best tools for the job .
I have exported and saved the license, so at least that part is done in case the device completely dies.
I have found it a bit of a struggle trying to find the 16MB chip though and Mikrotik won’t say what is it, or where it is located.
*I found it on the board…
Does Mikrotik have a service like Dell where you can look up the serial to confirm warranty status?
