CRS326-24G-2S+ with RouterOS - Switch and VLAN configuration
Can somebody explain me why switch configuration of CRS326-24G-2S+ is totally different than on models CRS125-24G-1S or CRS112-8G-4S?
I have almost same configuration (CRS326-24G-2S+ don’t have same options) on each one, but on CRS326-24G-2S+ I have not communication between hosts on ethernet ports and host connected to company WiFi which is on the same VLAN. From router (connected to eth1) I see all hosts.
Interface configuration:
set [ find default-name=ether1 ] name=eth1_trunk
set [ find default-name=ether2 ] master-port=eth1_trunk name=eth2_wap
set [ find default-name=ether3 ] master-port=eth1_trunk name=eth3_wap
set [ find default-name=ether4 ] master-port=eth1_trunk name=eth4_wap
set [ find default-name=ether5 ] master-port=eth1_trunk name=eth5_lan
set [ find default-name=ether6 ] master-port=eth1_trunk name=eth6_lan
set [ find default-name=ether7 ] master-port=eth1_trunk name=eth7_lan
set [ find default-name=ether8 ] master-port=eth1_trunk name=eth8_lan
set [ find default-name=ether9 ] master-port=eth1_trunk name=eth9_lan
set [ find default-name=ether10 ] master-port=eth1_trunk name=eth10_lan
set [ find default-name=ether11 ] master-port=eth1_trunk name=eth11_lan
set [ find default-name=ether12 ] master-port=eth1_trunk name=eth12_lan
set [ find default-name=ether13 ] master-port=eth1_trunk name=eth13_lan
set [ find default-name=ether14 ] master-port=eth1_trunk name=eth14_lan
set [ find default-name=ether15 ] master-port=eth1_trunk name=eth15_lan
set [ find default-name=ether16 ] master-port=eth1_trunk name=eth16_lan
set [ find default-name=ether17 ] master-port=eth1_trunk name=eth17_lan
set [ find default-name=ether18 ] master-port=eth1_trunk name=eth18_lan
set [ find default-name=ether19 ] master-port=eth1_trunk name=eth19_lan
set [ find default-name=ether20 ] master-port=eth1_trunk name=eth20_lan
set [ find default-name=ether21 ] master-port=eth1_trunk name=eth21_lan
set [ find default-name=ether22 ] master-port=eth1_trunk name=eth22_lan
set [ find default-name=ether23 ] master-port=eth1_trunk name=eth23_lan
set [ find default-name=ether24 ] master-port=eth1_trunk name=eth24_lan
add name=bridge_trunk
/interface vlan
add interface=bridge_trunk name=vlan_lan vlan-id=100
add interface=bridge_trunk name=vlan_wlan vlan-id=200
set 4 default-vlan-id=100
set 5 default-vlan-id=100
set 6 default-vlan-id=100
set 7 default-vlan-id=100
set 8 default-vlan-id=100
set 9 default-vlan-id=100
set 10 default-vlan-id=100
set 11 default-vlan-id=100
set 12 default-vlan-id=100
set 13 default-vlan-id=100
set 14 default-vlan-id=100
set 15 default-vlan-id=100
set 16 default-vlan-id=100
set 17 default-vlan-id=100
set 18 default-vlan-id=100
set 19 default-vlan-id=100
set 20 default-vlan-id=100
set 21 default-vlan-id=100
set 22 default-vlan-id=100
set 23 default-vlan-id=100
add bridge=bridge_trunk interface=eth1_trunk
add ports="switch1-cpu,eth1_trunk,eth2_wap,eth3_wap,eth4_wap,eth5_lan,eth6_lan,eth7_lan,eth8_lan,eth9_lan,eth10_lan,eth11_lan,eth12_lan,eth13_lan,eth14_lan,eth15_lan_,eth16_lan,eth17_lan,eth18_lan,eth19_lan,eth20_lan,eth21_lan,eth22_lan,eth23_lan,eth24_lan" switch=switch1 vlan-id=100
add ports=eth1_trunk,eth2_wap,eth3_wap,eth4_wap switch=switch1 vlan-id=200
CAPS-MAN Configuration:
/caps-man datapath
add bridge=bridge_trunk name=lan_vlan100 vlan-id=100 vlan-mode=use-tag
add bridge=bridge_trunk name=wlan_vlan200 vlan-id=200 vlan-mode=use-tag
/caps-man configuration
add channel.band=2ghz-b/g/n datapath=lan_vlan100 ssid="Company WiFi" name=cfg_lan_2GHz
add datapath=wlan_vlan200 security=wpa_wlan ssid="Guest WiFi" name=cfg_wlan
add channel.band=5ghz-a/n/ac datapath=lan_vlan100 ssid="Company WiFi" name=cfg_lan_5GHz
/caps-man provisioning
add action=create-enabled hw-supported-modes=gn master-configuration=cfg_lan_2GHz slave-configurations=cfg_wlan
add action=create-enabled hw-supported-modes=ac master-configuration=cfg_lan_5GHz slave-configurations=cfg_wlan
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
Thanks in advance!
Best regards,
Mladen
I forgot to say that I use last stable 6.40.5 version.
I tried also with version 6.41rc61 because new hw-offload configuration in bridge settings and than nothing was working (conf. from wiki). Example, after setting VLAN filtering = yes I get lost communication with switch. Print command in bridge are very slow…
Mikrotik support,
is this cloud switch stable with RouterOS or I must use SwOS?
