Hi All,
I’m looking into the possibility of creating some VLANs on the above switch. Firstly, is this possible ? Secondly I have had experience in creating VLAN and assigning each VLAN its own IP/Gateway on HP Aruba Switches - Is it similar on Mikrotik ?
Can someone point me in the direction of how I would configure the switch so I can for example;
Configure Port 1 on VLAN 10 - Subnet: 192.168.10.0/24
Configure Port 2 on VLAN 20 - Subnet: 192.168.20.0/24
Configure Port 3 on VLAN 30 - Subnet: 192.168.30.0/23
Configure Port 48 - Uplink port to Firewall.
As the example above I do not want the devices in ports 1,2,3 to be able to communicate to each other - but would be good to know the config should that be needed in the future.
Can I set up DHCP on the VLANs on this switch? So when I plug a device into a port it will be given the correct range
Is it possible to do the above or will I require a layer 3 device - Can this switch do layer 3 ? I have seen mention of it previously.
If the above is not possible what do I need to do to be able to achieve this - place a layer 3 device between the uplink and firewall?
Thanks in advance.
