CRS804 - Can a single QSFP-DD port support 2×100GBASE-CR4 breakout to two ConnectX-5 NICs
I’m considering getting a CRS804-4DDQ-hRM for my home server cluster and have a quick question about breakout compatibility.
I have two servers, each with a Mellanox ConnectX-5 (MCX516A-CDAT) 100GbE NIC.
I’d like to connect both to a single QSFP-DD port on the CRS804 using a passive QSFP-DD to 2×QSFP28 breakout DAC.
From what I understand, this would use 8×25G lanes on the switch side, split into two 4×25G (100GBASE-CR4) connections.
The documentation mentions 8×25G breakout and 4×100GBASE-CR2, but I couldn’t find confirmation that 2×100GBASE-CR4 is supported.
Has anyone tried this, or knows if it would work? Would both connections show up independently in RouterOS?
Would love to keep my existing NICs and save a switch port if possible.
Thanks! :slight_smile:
