css610-8g-2s+in poe to port1 no power
Hi
I just bought one of these and have tried to power up the CSS610 via POE IN port1, I have tried with a Netgear ProSafe JG524PE and an Aruba InstantOn 1930 switch and cannot power up
Has anyone powered theirs up via POE IN, if anyone can shed light on this I would be grateful
This switch only supports Passive PoE, not PoE that is present on many switches, you may be able to find some converters.
I have successfully used this: Gigabit PoE Splitter 12V 1A… https://www.amazon.co.uk/dp/B08HS4Z7JQ?ref=ppx_pop_mob_ap_share
It talks to the switch using 802.3af standard and splits it out to a gigabit link and a barrel connector for power.
I have my Microtik switch linked to a UniFi switch using 4 links, this allows the switch to be powered from one of the trunk cables.
I am also planning to use this active Poe splitter to power another switch as well as link another device via the 1Gb link.
