custom channel width activation
hello ..
i want to know, can i activate extra channel license on rb433ah lv5 with r52hn ?
i want to use custom channel width (ex 30mhz channel width)
i already have rb800 lv6 with extra channel features activated and r52hn , and able to create custom channel width (30mhz), tested connection with nanostation m5 channelwidth 30mhz
regards
SOLVED !!!
make a request to mikrotik to activate feature in the account ,and then just upgrade the license
able to create custom channel width (rb433ah + r52hn)
thx mikrotik
license level impose limitations on radio channels??
not in radio channel , but in custom channel width (ex 25mhz , 30mhz), because my client cpe use ubnt
so i have different option for channel width outside standard mikrotik channel width (5,10,20,20/40) to paired with ubnt cpe
.. limitation is only on supported wireless chipset (ar92xx family) , i use r52hn in my mikrotik ap
Wouldn’t be easier and maybe cheaper to use the same brand devices on both sides?
hi guys am new here so i need a help in something..
where i live there is a lot of radio noise what i want is is there any possible way to buy a license that i can open extra channel below 5000 MHz so how it can be done ??!!!
