Custom skins, Selectable user from the dropdown
I have hotspot with User Manager configured on MikroTik RouterOS v7.14.3.
I did create a custom skin for the end user to be able to create username/password.
My question is : it it possible to change the skin so the username value will be only selectable from the dropdown list and only password should be specified manually?
My idea is to make the authentication look like using the PMS : login : room-number and Passowrd: Customer-Name.
when the customer do the checkin, the receptionist create an access to him using already predefined Room number and he should only enter the password.
Thank you
you can create the index2.html page and load it into mikrotik with branding package. in this you modify the username field to your liking
I think index.html is for router authentication, I’m talking about hotspot username/password code creation.
I misunderstood, then you can edit the login.html file and if necessary also style.css. Skills regarding this protocols are needed.
I see you are still misunderstanding my request.
I’m not talking about Hotspot authentication page but voucher creation.
1- I did create a custom skin with very limited options(bellow the screenshoot),for the Hotel receptionist so he can create wifi code access:
2- My question it is possible to make the receptionist choose the Username from the predefined list (That will make it Room Number)so he can only specify the password which will be the guest name.
Example:
