Thank you very much for the report. The particular issue is resolved and will be available in the next version. Currently you can use workaround and close customer edit window with ‘cross’ button and not with ‘save’ button.
I have been working with it for a bit now and see the issue.
The templase saves correctly, but when tou “SAVE” the customer profile, it resets the html. (OOPS)..
Therfore ANY changes to the customer page will reset your html.
You are advised to keep a copy of it on hand off of the router !!
You can work with the current release in the folowing manor:
open the customer you want to edit.
press the edit template button.
edit the html as described in the WIKI.
save the html.
HERE is the important part !!!
DO NOT PRESS SAVE on the customer main page !!!
If you do, the html is reset…
Instead close the “sub page” using the “x” at the top right hand corner of the “sub page”..
