DDNS Double NAT Script
Hello
I’m trying to reach a Mikrotik Hap ax2 behind a double NAT public address. I have setup a Dynu account and found a script for a double NAT connection. On the post for the double NAT script it says " Note that you need to escape the special characters such as “ and $ and also to insert the \r\ and \n line control characters." I am a nube at scripting. Please can someone help me to fix the script to get it working?
[# get the current IP address from the internet
/tool fetch mode=http address=“checkip.dynu.com” src-path=“/”
dst-path=“/dynu.checkip.html”
:local result [/file get dynu.checkip.html contents]
parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local currentIP [:pick $result $startLoc $resultLen]
:global ddnsuser your_Dynu_username
:global ddnspass “your_Dynu_password”
:global ddnshost “your_Dynu_hostname”
:global ipddns [:resolve $ddnshost];
#:global ipddns
:if ($ipddns != $currentIP) do={
:log info (“DynuDDNS: IP-Dynu = $ipddns”)
:log info (“DynuDDNS: IP-Fresh = $currentIP”)
:log info “DynuDDNS: Update IP needed, Sending UPDATE…!”
:global str “/nic/update?hostname=$ddnshost&myip=$currentIP”
:log info “currentIP is $currentIP”
/tool fetch address=api.dynu.com src-path=$str mode=http user=$ddnsuser password=$ddnspass
dst-path=(“/Dynu.”.$ddnshost)
:delay 1
:global str [/file find name=“Dynu.$ddnshost”];
/file remove $str
:global ipddns $currentIP
:log info “DynuDDNS: IP updated to $currentIP!”
} else={
:log info “DynuDDNS: No change needed”;
See http://forum.mikrotik.com/t/script-execution-error-dynu-com-7-13-was-fine-7-15-no-bueno/176540/1
