Dead hardware?
Hello people!!
I have a CloudCore CCR-1036 Router which was working fine for many years
Recently it stoped working, now it shows a lot of blinking lights and make a weird sound, like an stucked fan
As soon as I connect the router only with power cable, happen the following:
  • Ether5 to ether8, are with the green light blinking
  • All other ethernet ports are with both green and orange lights blinking
  • The light at the right of the console port also is blinking (There are 2 leds at the right of the console port, which is dows is wich is blinking)
  • If I connect an ethernet cable to a PC, the PC does not see the link (like disconnected cable)
I tried to reset to factory default with the reset button, and tried to netinstall with no luck, still the same behavior and it is not being found by netinstall.
Is there another step to try bring it back?
Thanks in advance
Regards,
Damián
If the fan failed, it’s possible that the CPU is overheating and causing system errors or that it has been damaged. You should be able to replace the fan and this guide can help you troubleshoot other issues:
http://www.mkesolutions.net/descargas/manuales_rb/CCR.pdf
Or contact Mikrotik directly…
Thanks Moba,
I will try
