Debian's rsyslogd & remote logging
So I’ve got the daemon running on all IP’s of my debian server
udp        0      0 0.0.0.0:514             0.0.0.0:*
I have the remote logging setup
admin@dcomfap-rt01] /system logging> print
 #   TOPICS        ACTION        PREFIX
 0   info        memory
 1   error        memory
 2   warning        memory
 3   critical        echo
 4   error        remote        dcomfap...
     warning
     critical
     manager
     account
And the action setup on the /system logging action menu
[admin@dcomfap-rt01] /system logging action> print
Flags: * - default
 #   NAME        TARGET REMOTE
 0 * memory        memory
 1 * disk        disk
 2 * echo        echo
 3 * remote        remote 66.228.56.x
I’m not getting any traffic on the debian server and the logs are flying by entries locally.
Since they’ve moved to rsyslogd in debian, has anyone had any similar issues?
having run tshark on the server, there is no traffic coming in from the routers so I’m 99% that the traffic isn’t being generated at the router side.
What version are you running? Under 5.x I’ve found that I have to specify a src-address for the remote entry under “/system logging action” or it doesn’t send anything.
yeah i’m 5.2
trying that now!
 3 * name="remote" target=remote remote=66.228.56.x remote-port=514 src-address=173.12.150.x bsd-syslog=no syslog-facility=daemon syslog-severity=auto
that look about right?
no dice :frowning:
I know the two communicate because SNMP polling is working fine. Ugh how frustrating.
Can you please post the output of “/ip address print detail” and “/system logging export”? If that still looks good I guess it’s time for an official bug report.
[admin@dcomfap-rt01] /system logging action> /ip address print detail
 0   ;;; default configuration
     address=172.30.7.1/24 network=172.30.7.0 interface=ether2-local-master actual-interface=ether2-local-master
 1   address=173.12.150.x/30 network=173.12.150.x interface=ether1-gateway actual-interface=ether1-gateway
 2 D address=172.16.1.2/32 network=172.16.1.1 interface=pptp-out1 actual-interface=pptp-out1
# may/16/2011 16:31:17 by RouterOS 5.2
# software id = C9GJ-1G3X
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=66.228.56.x remote-port=514 src-address=173.12.150.x syslog-facility=daemon syslog-severity=auto target=remote
/system logging
add action=remote disabled=no prefix=dcomfap-rt01 topics=info,error,warning,critical,account
Try making one entry per topic. Lists of topics are logical ANDs.
/system logging
remove [find]
add action=remote disabled=no prefix=dcomfap-rt01 topics=error
add action=remote disabled=no prefix=dcomfap-rt01 topics=warning
add action=remote disabled=no prefix=dcomfap-rt01 topics=critical
add action=remote disabled=no prefix=dcomfap-rt01 topics=account
that did it. thank you very much!
was this bad practice at having a single rule for the remote or was that a bug?
I think it has always been a logical AND, it’s not a bug.
Basically, many messages are subscribed to several topics at once. For example a lot of debug output is part of “debug” but also part of “packet”. The manual example is if you want detailed NTP debug output, but not too much, you can subscribe to “ntp,debug,!packet” - which means all log messages that are part of NTP and debug, but not on a packet level. So a list of topics isn’t really a list of all topics you’d like to see logged - it’s a list of topics a single log message must match in order to be logged to that target.
gotcha! thanks
