Dedicated Bandwidth Manager
Hello forum,
I need assistance on how I can convert Router OS to a dedicated (transparent) bandwidth manager using its powerful Queue package. I’d need setup to shape the tx/rx data rate based on IP address of a customer whose traffice passes (transparently) through the router. I probable would have to configure its two interfaces onto a bridge, etc… (I may be wrong, somebody correct me :wink:)
Any one with ideas, step-by-step direction on how to implement this?
Tonnie
See this:
http://www.mikrotik.com/docs/ros/2.8/ip/firewall.main.2
A simple analysis of this diagram shows that there’s nothing difficult in your question.
  1. configure bridge on two interfaces (refer to bridge manual)
/interface bridge port set ether1,ether bridge=bridge1
  1. add simple queues based on dst/src addresses
    (you may use ‘mangle’ feature to do this - refer to Bandwith Management manual)
