Desperated begginer in mikrotik routers - routing problem
Dear all proffesionals i need your help in configuring network with mikrotik routers.
How do i route traffic beetwen 2 router and 2 subnet.
mikrotik 1200, port - 3 - 192.168.2.0/24
mikrotik 1200, port - 5 - 192.50.80.1/28
On 192.168.2.0 are the users i need to route trafic so that they can access on 192.50.80.1 so that can join domain controller and use other resource.
Internet is fixed on mikrotik 1200, just need to route trafic to access other resource on 1100.
on one router you only have to set up a default route, if traffic goes through the other router, if not, you have to set up extra route that will point traffic towards the other network.
On second router you have to set-up a mirror route so that subnet you want can be reached through different route but connected or default.
Ok. I will make the coffie and try it.
I will be back later with the results.
