Device name in Function code
Is it possible to use device name as search string in the function code?
For example I putted “AP1” as device name and I want to find the position of this device name in the array of oid’s.
Command: array_find(oid_column(“1.3.6.1.4.1.9.9.513.1.1.1.1.5”), “AP1”) …it works fine
Command: array_find(oid_column(“1.3.6.1.4.1.9.9.513.1.1.1.1.5”), Device.Name()) … doesn’t work
Thanks and best regards
