I’ve followed the very good guide on VLANs:
However, anything connected to the switch does not get an IP address from the router. I have looked at the leases and while the other networks (all connected through wifi) work fine, the devices connected to the switch are not.
Connecting to the wifi access point associated with the same VLAN as the ports on the switch works fine.
Router ehter1 is connected to the modem, ether2 connected to switch
Switch ether1 connected to the router, with clients on ether2 and ether4.
Scripts below.
Thank you!
Router (hap ac2):
# Topic: Using RouterOS to VLAN your network
# Example: Switch with a separate router (RoaS)
# Web: http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
# RouterOS: 6.43.12
# Date: Mar 28, 2019
# Notes: Start with a reset (/system reset-configuration no-defaults=yes skip-backup=yes run-after-reset=flash/router.rsc)
# Thanks: mkx, sindy
:delay 30s
# Housekeeping
# name the device being configured
/system identity set name="MainRouterSwitch"
/system clock set time-zone-name=Asia/Jerusalem
# VLAN Overview
# 60 = GUEST (GREEN)
# 70 = RED
# 80 = BLUE
# 99 = BASE (MGMT) VLAN
# Bridge
# create one bridge, set VLAN mode off while we configure
/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
# WIFI Setup
# BASE SSID, admin level access to Winbox the device. Use a local ethernet port if preferred.
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key=""
/interface wireless set [ find default-name=wlan1 ] ssid=Home frequency=auto mode=ap-bridge disabled=no distance=indoors band=2ghz-b/g/n channel-width=20/40mhz-XX wireless-protocol=802.11
/interface wireless set [ find default-name=wlan2 ] ssid=Home frequency=auto mode=ap-bridge disabled=no distance=indoors band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX wireless-protocol=802.11
# GUEST SSID
/interface wireless security-profiles add name=HomeGuest authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key=""
/interface wireless add name=wlan3 ssid=HomeGuest master-interface=wlan1 security-profile=HomeGuest disabled=no
/interface wireless add name=wlan4 ssid=HomeGuest master-interface=wlan2 security-profile=HomeGuest disabled=no
# RED SSID
/interface wireless security-profiles add name=HomeUntrusted authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key=""
/interface wireless add name=wlan5 ssid=HomeUntrusted master-interface=wlan1 security-profile=HomeUntrusted disabled=no
/interface wireless add name=wlan6 ssid=HomeUntrusted master-interface=wlan2 security-profile=HomeUntrusted disabled=no
# BLUE SSID
/interface wireless security-profiles add name=HomeSafe authentication-types=wpa2-psk mode=dynamic-keys wpa2-pre-shared-key=""
/interface wireless add name=wlan7 ssid=HomeSafe hide-ssid=yes master-interface=wlan1 security-profile=HomeSafe disabled=no
/interface wireless add name=wlan8 ssid=HomeSafe hide-ssid=yes master-interface=wlan2 security-profile=HomeSafe disabled=no
# -- Access Ports --
# ingress behavior
# BASE VLAN
add bridge=BR1 interface=wlan1 pvid=99
add bridge=BR1 interface=wlan2 pvid=99
# GUEST
add bridge=BR1 interface=wlan3 pvid=60
add bridge=BR1 interface=wlan4 pvid=60
# RED
add bridge=BR1 interface=wlan5 pvid=70
add bridge=BR1 interface=wlan6 pvid=70
# BLUE
add bridge=BR1 interface=wlan7 pvid=80
add bridge=BR1 interface=wlan8 pvid=80
# egress behavior, handled automatically
# -- Trunk Ports --
# ingress behavior
# Purple Trunk. Leave pvid set to default of 1
add bridge=BR1 interface=ether2
add bridge=BR1 interface=ether3
add bridge=BR1 interface=ether4
add bridge=BR1 interface=ether5
# egress behavior
/interface bridge vlan
# Purple Trunk. These need IP Services (L3), so add Bridge as member
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5 vlan-ids=60
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5 vlan-ids=70
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5 vlan-ids=80
add bridge=BR1 tagged=BR1,ether2,ether3,ether4,ether5 vlan-ids=99
# IP Addressing & Routing
# LAN facing router's IP address on the BASE_VLAN
/interface vlan add interface=BR1 name=BASE_VLAN vlan-id=99
/ip address add address=192.168.0.1/24 interface=BASE_VLAN
# DNS server, set to cache for LAN
/ip dns set allow-remote-requests=yes servers="1.1.1.1,1.0.0.1"
# PPoE used instead of the config below
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=... use-peer-dns=no user=...
# WAN facing port with IP Address provided by ISP
# /ip address add interface=ether1 address=a.a.a.a/aa network=a.a.a.0
# router's gateway provided by ISP
# /ip route add distance=1 gateway=b.b.b.b
# IP Services
# GUEST VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=GUEST_VLAN vlan-id=60
/ip address add interface=GUEST_VLAN address=10.0.60.1/24
/ip pool add name=GUEST_POOL ranges=10.0.60.2-10.0.60.254
/ip dhcp-server add address-pool=GUEST_POOL interface=GUEST_VLAN name=GUEST_DHCP disabled=no
/ip dhcp-server network add address=10.0.60.0/24 dns-server=192.168.0.1 gateway=10.0.60.1
# RED VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=RED_VLAN vlan-id=70
/ip address add interface=RED_VLAN address=10.0.70.1/24
/ip pool add name=RED_POOL ranges=10.0.70.2-10.0.70.254
/ip dhcp-server add address-pool=RED_POOL interface=RED_VLAN name=RED_DHCP disabled=no
/ip dhcp-server network add address=10.0.70.0/24 dns-server=192.168.0.1 gateway=10.0.70.1
# BLUE VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=BLUE_VLAN vlan-id=80
/ip address add interface=BLUE_VLAN address=10.0.80.1/24
/ip pool add name=BLUE_POOL ranges=10.0.80.2-10.0.80.254
/ip dhcp-server add address-pool=BLUE_POOL interface=BLUE_VLAN name=BLUE_DHCP disabled=no
/ip dhcp-server network add address=10.0.80.0/24 dns-server=192.168.0.1 gateway=10.0.80.1
/ip dhcp-server lease add address=10.0.80.2 mac-address=... server=BLUE_DHCP
# Optional: Create a DHCP instance for BASE_VLAN. Convenience feature for an admin.
/ip pool add name=BASE_POOL ranges=192.168.0.10-192.168.0.254
/ip dhcp-server add address-pool=BASE_POOL interface=BASE_VLAN name=BASE_DHCP disabled=no
/ip dhcp-server network add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
# Firewalling & NAT
# A good firewall for WAN. Up to you
# about how you want LAN to behave.
# Use MikroTik's "list" feature for easy rule matchmaking.
/interface list add name=WAN
/interface list add name=RED
/interface list add name=BLUE
/interface list add name=BASE
# WAN/internet (was ether1, but ISP uses pppoe)
# Access internet, RED from each other
add interface=BASE_VLAN list=RED
add interface=GUEST_VLAN list=RED
add interface=RED_VLAN list=RED
# BLUE is REDd and has no internet access
add interface=BLUE_VLAN list=BLUE
# Base can access everything
add interface=BASE_VLAN list=BASE
# VLAN aware firewall. Order is important.
# INPUT CHAIN
add chain=input action=accept connection-state=established,related comment="Allow Estab & Related"
# Allow VLANs to access router services like DNS, Winbox.
add chain=input action=accept in-interface-list=RED comment="Allow VLAN"
# Allow BASE_VLAN full access to the device for Winbox, etc.
add chain=input action=accept in-interface=BASE_VLAN comment="Allow Base_Vlan Full Access"
# Allow server to access router services like DNS, Winbox.
add chain=input action=accept src-address=10.0.80.2 src-mac-address=... comment="Allow Server"
# Allow router services for BLUE
add chain=input action=accept in-interface-list=BLUE comment="Allow VLAN"
add chain=input action=drop comment="Drop"
# FORWARD CHAIN
add chain=forward action=accept connection-state=established,related comment="Allow Estab & Related"
# Allow RED VLANs to access the Internet only, NOT each other
add chain=forward action=accept connection-state=new in-interface-list=RED out-interface-list=WAN comment="VLAN Internet Access only"
# Allow BASE VLAN to access everything
add chain=forward action=accept connection-state=new in-interface=BASE_VLAN comment="BASE VLAN all access"
# Allow server to access the Internet only, NOT other VLANs
add chain=forward action=accept connection-state=new src-address=10.0.80.2 src-mac-address=... out-interface-list=WAN comment="Allow Server"
add chain=forward action=drop comment="Drop"
# NAT
/ip firewall nat add chain=srcnat action=masquerade out-interface-list=WAN comment="Default masquerade"
# VLAN Security
# Only allow packets with tags over the Trunk Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether2]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether3]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether4]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether5]
# MAC Server settings
# Ensure only visibility and availability from BASE_VLAN, the MGMT network
/ip neighbor discovery-settings set discover-interface-list=BASE
/tool mac-server mac-winbox set allowed-interface-list=BASE
/tool mac-server set allowed-interface-list=BASE
# Turn on VLAN mode
/interface bridge set BR1 vlan-filtering=yes
Switch (CRS112-8P-4S-IN):
# RouterOS: 6.43.13
# Date: April 15, 2021
# Notes: Start with a reset (/system reset-configuration no-defaults=yes skip-backup=yes run-after-reset=flash/switch.rsc)
:delay 30s
# Naming
/system identity set name="CameraSwitch"
# VLAN Overview
# 80 = BLUE
# Other VLANS, not used here, may be defined elsewhere
# Bridge
# ingress behavior
# BLUE VLAN
add bridge=BR1 interface=ether2 pvid=80
add bridge=BR1 interface=ether3 pvid=80
add bridge=BR1 interface=ether4 pvid=80
add bridge=BR1 interface=ether5 pvid=80
add bridge=BR1 interface=ether6 pvid=80
add bridge=BR1 interface=ether7 pvid=80
add bridge=BR1 interface=ether8 pvid=80
# -- Trunk Ports --
# ingress behavior
add bridge=BR1 interface=ether1
add bridge=BR1 interface=sfp9
add bridge=BR1 interface=sfp10
add bridge=BR1 interface=sfp11
add bridge=BR1 interface=sfp12
# egress behavior
# Purple Trunk. L2 switching only, Bridge not needed as tagged member (except BASE_VLAN)
set bridge=BR1 tagged=ether1,sfp9,sfp10,sfp11,sfp12 [find vlan-ids=80]
add bridge=BR1 tagged=BR1,ether1,sfp9,sfp10,sfp11,sfp12 vlan-ids=99
# LAN facing Switch's IP address on a BASE_VLAN
/ip address add address=192.168.0.2/24 interface=BASE_VLAN
# The Router's IP this switch will use
/ip route add distance=1 gateway=192.168.0.1
# IP Services
# We have a router that will handle this. Nothing to set here.
# VLAN Security
# Only allow ingress packets without tags on Access Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether2]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether3]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether4]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether5]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether6]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether7]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether8]
# Only allow ingress packets WITH tags on Trunk Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=ether1]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=sfp9]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=sfp11]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-vlan-tagged [find interface=sfp12]
/interface list member add interface=BASE_VLAN list=BASE
# Turn on VLAN mode
