Hi!
I have a strange behavior with one of my routerboards:
The RB get the IP address from a dhcp server. The server (Cisco L3 Switch) offers ip, default-gateway, dns, ntp and dhcp-option 121 (a static route). The last one is needed because every client need a route besides the default route to reach a certain network. Everything works fine with the windows and linux clients, but then i want to connect a routerboard to the network:
I configured the dhcp-client, it get an ip adress, add the route from dhcp-option 121, but it will not add the default route! And, yes, i have set the option “Add default route” in the dhcp-client configuration. Unsetting this option will delete the dynamic learned route from option 121 ![]()
The thing is: After removing dhcp-option 121 from the server configuration, the RB creates the default route. Somebody has a clue how to fix this?
I need the default route AND the route set via option 121.
