Hello all,
my ISP provide us with some devices, that should be placed “before” router. He suggest to connect uplink cable to switch and from there to his devices and our router. I don´t want to use extra device so my plan is to reconfigure my hAP ac2 like this:
Ethernet ports 1,2,3 will be on “WAN bridge”. Ether1 for uplink, Ether2 and 3 for devices from ISP.
Ethernet ports 4,5 and WLAN should be used for LAN.
I use this config:
# sep/24/2021 16:01:22 by RouterOS 6.47.10
# model = RBD52G-5HacD2HnD
add name=bridge_wan
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge_wan interface=ether1
add bridge=bridge_wan comment=defconf interface=ether2
add bridge=bridge_wan comment=defconf interface=ether3
add bridge=bridge comment=defconf hw=no interface=ether4
add bridge=bridge comment=defconf hw=no interface=ether5
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=bridge_wan list=WAN
/ip dhcp-client
# DHCP client can not run on slave interface!
add disabled=no interface=ether1
It works OK, but I get this error in the log:
temporary moving client ether1 from slave to master port, update your config!!!
Should I move DHCP Client from ether1 to bridge_wan?
Will it maintain same functionality?
Is there any better way to solve this problem?
I tried to change DHCP Client from ether1 to bridge and it seem like its working. Router receives IP address as before and there are no errors in the log.
As far as I understood, if you attach an interface to a bridge, the DHCP client also needs to be on that bridge.
If you really want to have the DHCP client on that interface, remove it from the bridge.
And create the necessary routes.
As you see this seems to work, but I have concern about second bridge - only one bridge is hardware accelerated (on most MT devices). All other bridges goes through CPU and that have a hit on router performance. A better solution would be vlans. (Theoretically, I have little experience whit it)
maigonis
Yes, on hAP ac2 I can choose just one bridge to have hardware offload, so I have chosen one where I expect more traffic. It is just small home network, so I don´t expect much load on CPU.
Zacharias
On left, there is topology recommended by provider. His Set Top Boxes use some streaming service that don´t get trough most routers.
On right, this is topology I want to use, but with same functionality as left one. I want this two Set Top Boxes to be on the network of my provider, not on my LAN.
Well, the simplest thing you can do is create two different bridges, one for the Set top boxes and the other for your LAN network …
However, that extra device ( the Switch ), is that provided by your ISP ?
Maybe it has VLANs configured… you have any details on that ? If you don’t use that extra device, can you still reach the Internet ?
Which is what the OP did to avoid having an additional switch, and moving the DHCP client from ether1 to bridge_wan correctly resolves the DHCP client can not run on slave interface warning.
Unless there will be significant traffic directly between the wired LAN ports (ether4 and ether5 in this case) there seems little point in using a single bridge and configuring the switch chip directly (a VLAN-aware bridge would disable all hardware offloading) as any routed and wireless interface traffic is handled by the CPU anyway.
Zacharias
This extra device is just regular unmanaged switch. I suspect this Set Top Boxes use VLANs, but ISP don´t share any info about it. Is there any way to figure it out on my own?
tdw
Based on what you wrote I think solution with two bridges should by OK. I don´t expect any significant traffic between devices and most of the devices will be on Wi-Fi anyway so HW offload will not affect them.
