I had the same problem and the fix was to switch around the modes from b/g/n to g/n and to only-n, and that would eventually get it to connect. Also, make sure you’ve enabled tkip in the security profile. ROS WiFi tends to work best with other ROS devices, and that’s probably why they’re not officially WiFi-certified.
Thank you very much but for compatibility reasons, I cannot abandon 802.11b.
But it sounds a good thinking. So after I change channel width from 20/40 to 20, all works fine.
What’s more, because aes has higher speed than tkip, I don’t think enable tkip is a good idea.
When using ROS device as wireless client, it doesn’t matter what options you have enabled (e.g. tkip, b/g, …) because client can not force AP to work in certain way, client has to follow AP’s setup to certain degree and AP preferences overrule client’s if both support same features. So if you disable a few things too many, it may happen client won’t connect if AP doesn’t support the limited options enabled on client.
Notable exception is using only 20MHz channels which forces communication to single 20MHz channel (which is mandatory to support for all 802.11 variations so far). If this setting helps (and keeping in mind that 5GHz seems to work fine), then this likely indicates lots of interference and using single 20MHz channel helps (because Tx power per megahertz is double compared to using 20+20MHz channels).
