dhcp-client problem with Virgin Media
I have a brand new hAP ax³ and am struggling to connect it to my Virgin Media broadband. I suspect I may be suffering from the dhcp client issues described in RouterOS beta and rc versions.
To me, it looks like the DHCP options are presented in Code order, so hostname(12) is before DHCP Message Type (Discover)(53).
I tried to remove hostname(12) but this failed with Default options are not removable! using the CLI. Also had a similar failure using WinBox.
How can I persuade my hAP ax³ to connect? I didn’t have similar problems with my old Buffalo WZR-HP-G300NH running OpenWrt …
