i have rb5009 with css610 switch and wap-ax. i am testing with the rb as a client to my tp-link router and all is fine with dhcp client on the rb lan.bridge.
but, when i try to connect the rb eth1 directly to my isp i cannot figure out the dhcp setup. i tried dhcp client on the wan, eth1, and dhcp server on the lan.bridge, all ports, minus eth1, but it seems to go nuts and i see the isp ip on some ports and not others. either way, no internet.
seems like the suggested method is dhcp client on the wan and server on the bridge, but not working for me, any suggestions on what i am doing wrong?
if you are using ether1 as your upstream port to the ISP, remove it from the bridge then setup a dhcp client on ether1 and it should work
Please share your current config:
/export file=anynameyoulike
Remove serial and any other private info, post between preformatted text tags by using the </> button.
jaclaz
July 17, 2025, 9:58am
4
In Mikrotik world, it is not entirely unlike the gaming one, show your screenshot configuration or it didn’t happen.
Seriously, dhcp settings can be complex and other parts of the configuration may affect the way they work (or fail to work).
Post your configuration, instructions here:
Hello and welcome to the Mikrotik forum For all new users that uses RouterOS for the first time and have some questions regarding their config here is short tutorial on how to access RouterOS configuration using “WinBox” and how to export their configuration and posting it properly in their topic.
So after you unpack your new device and connect it to the power supply you need to connect it to the PC.
Be careful when connecting because to access your new router you need to use one of…
# THIS IS RUNNING AS CLIENT FROM ACCESS PORT ON TPLINK ROUTER TO WAN PORT (PLEASE SEE NEXT CONFIG AS RB WAN PORT DIRECTLY TO ISP)
# 2025-07-18 09:31:26 by RouterOS 7.19.1
# software id =
# model = RB5009UPr+S+
# serial number =
add name=lan.bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-MGMT
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-TO-SW-SR
/interface wifi configuration
add country=Philippines disabled=no mode=ap name=MAIN \
security.authentication-types=wpa2-psk,wpa3-psk .encryption="" ssid=\
casa-torino
/certificate settings
set builtin-trust-anchors=not-trusted
add bridge=lan.bridge interface=sfp-sfpplus1-TO-SW-SR
add bridge=lan.bridge interface=ether1-WAN
set discover-interface-list=all
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no identity-regexp=WAP* \
master-configuration=MAIN name-format="EAST-EAVE [WAP-AX-2GHz]" \
radio-mac=F4:1E:57:89:61:CE
master-configuration=MAIN name-format="EAST-EAVE [WAP-AX-5GHz]" \
radio-mac=F4:1E:57:89:61:CF
add action=create-dynamic-enabled disabled=no identity-regexp=CAP* \
master-configuration=MAIN name-format="BEDROOM 4 [CAP-XL-AC-5GHz]" \
radio-mac=48:A9:8A:F1:83:0B slave-name-format=""
master-configuration=MAIN name-format="BEDROOM 4 [CAP-XL-AC-2GHz]" \
radio-mac=48:A9:8A:F1:83:0A
master-configuration=MAIN name-format="HALL-UPSTAIRS [CAP-XL-AC-5GHz]" \
radio-mac=48:A9:8A:F1:84:63
master-configuration=MAIN name-format="HALL-UPSTAIRS [CAP-XL-AC-2GHz]" \
radio-mac=48:A9:8A:F1:84:62
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add default-route-tables=main interface=ether1-WAN
set allow-remote-requests=yes servers=8.8.8.8
/ip service
set ftp disabled=yes
set telnet disabled=yes
/system clock
set time-zone-name=Asia/Manila
/system identity
set name=CAPSMAN
/tool mac-server
set allowed-interface-list=dynamic
THIS IS CONFIG WHEN WAN ON ETH1 RB5009, GETTING ODD BEHAVIOR WHEN TRYING TO SET DHCP ON THE LAN BRIDGE.
2025-07-18 10:11:15 by RouterOS 7.19.1
software id =
serial number =
add name=lan.bridge
security.authentication-types=wpa2-psk,wpa3-psk .encryption=“” ssid=
casa-torino
add name=pool1 ranges=192.168.0.0/24
set enabled=yes package-path=“” require-peer-certificate=no upgrade-policy=
none
master-configuration=MAIN name-format=“EAST-EAVE [WAP-AX-2GHz]”
master-configuration=MAIN name-format=“EAST-EAVE [WAP-AX-5GHz]”
master-configuration=MAIN name-format=“BEDROOM 4 [CAP-XL-AC-5GHz]”
radio-mac=48:A9:8A:F1:83:0B slave-name-format=“”
master-configuration=MAIN name-format=“BEDROOM 4 [CAP-XL-AC-2GHz]”
master-configuration=MAIN name-format=“HALL-UPSTAIRS [CAP-XL-AC-5GHz]”
master-configuration=MAIN name-format=“HALL-UPSTAIRS [CAP-XL-AC-2GHz]”
add address=192.168.0.1/24 interface=lan.bridge network=192.168.0.0
/ip dhcp-client
add address=100.64.0.0/10 gateway=100.79.157.174
/ip service
/system clock
/system identity
set name=CAPSMAN
/tool mac-server
jaclaz
July 18, 2025, 12:54pm
7
In your first configuration the DHCP client isn’t running as you have the ether1 added to (slave to) the bridge:
In the second it should work (i.e. ether1 should get an IP address if connected to a DHCP server) but the device is doing nothing, i..e. it is not configured as a switch (since the bridge has ONLY the SFP in it) and not as a router (no nat/masquerade).
It is not at all clear (to me) how you actually want to configure it, but if as a switch, the bridge should have BOTH the SFP and ether1 added to it and the dhcp client should be running on the bridge, i.e.:
/ip dhcp-client
add interface=lan.bridge
I reset the RB5009 to default config. connected eth1 to starlink and no internet. cant ping the gateway 88.1 from other devices. disabled fw rules, no difference. as a default router config it cannot access internet?
# serial number =
add admin-mac=78:9A:18:D5:FC:31 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
192.168.88.0
/ip dhcp-client
192.168.88.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/tool mac-server
/tool mac-server mac-winbox
i think im good now, i understand better now and think i figured out my issue. thanks all.
