DHCP IMPORT Leas with file
How to format the file for import and how to import it best into DHCP server lease?
IP address, MAC address, comment.
Script.
Add some leases.
Export the script part.
Adjust as needed for the remaining part.
i need to combine it in excel do you have a better solution ?
Also did it using excel recently when transferring some stuff from MS DHCP server to RB5009.
Make sure the excel formats the commands as it needs to be and then it is copy- paste.
(replace tab with space…)
