Hi all,
I have created a wireless bridge using LHG XL 52 ac. You can read about what I did exactly in the link below. The setup is basically like follows:
The laptop, xbox, ps4 can all get DHCP addresses. However, when I make the LHG use a DHCP client, it cannot obtain the IP. It just keeps saying “searching”. Also if I set a static IP in the right range and with the right ip mask, it still cannot be pinged from my desktop. The desktop pc can always reach the LHG using the mac protocol. I just want the LHG to be able to connect to the internet so that I can auto-update, use the web interface, NTP, etc.
The LHG wlan1 interface is set to “station-pseudobridge” mode. And the only interface I can run the DHCP client on is “bridge”, the bridge interface that ties together the wireless and the ethernet. It won’t let me run the dhcp client on either wlan1 or ethernet because it doesn’t want to run on a slave interface.
This doesn't say that DHCP won't work. It just means that the other modes are preferable when possible, but that is only possible if the other side of the wireless connection is also MikroTik hardware, which is not the case here, therefore "avoiding this mode is not possible". It doesn't mean it's "broken" or whatever.
That’s what I’m trying to do, access it via IPv4. So I don’t see what you’re trying to say. Can you talk in whole sentences? This whole copy pasting manual lines without explanation shtick is very passive aggressive and clearly isn’t helping the situation either.
Nothing that you quoted in the manual actually says what you said here. I'm just going to ignore your messages from now on. It seems like you have a habit of posting a lot.
