Hi everyone,
I am using a RouerBoard RB450G with RouterOS v5.0.
I set up a DHCP Server on interface ether3 and it works fine.
However, when I check the log I notice 2 problems as you can see in the pictures.
- dhcp warning dhcp1 offering lease 10.0.10.69 for 00:23:14:52:B4:B4 to B8:AC:6F:63:03:7C without success
This only happens to one IP and two MAC as above.
- DHCP Server deassigned and assigned an IP at a same time.
12:27:20 dhcp1 deassigned 10.0.10.62 from 00:0D:0B:B9:27:01
12:27:20 dhcp1 assigned 10.0.10.62 to 00:0D:0B:B9:27:01
This happens to some IPs and MAC addresses.
- An IP is assigned and deassigned many times in a short time.
Here is the DHCP Server Config
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static disabled=no interface=ether3-local lease-time=2d name=dhcp1
/ip dhcp-server config
set store-leases-disk=5m
add address=10.0.0.0/16 dns-server=8.8.8.8,210.245.24.22,203.162.4.1,203.162.4.190,208.67.222.222 gateway=10.0.10.1
Here is the Interface ether3
mac-address=00:0C:42:A2:98:2F master-port=none mtu=1500 name=ether3-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1524
So I hope I can have an explanation about why this happen and how could I fix this.
Thank you very much.
