MT Main config :
[admin@MTmain] > export
# nov/05/2023 13:51:30 by RouterOS 6.49.10
# software id = R483-S3DQ
# model = RBD52G-5HacD2HnD
add admin-mac=B8:69:F4:18:B0:E2 arp-timeout=30s auto-mac=no frame-types=admit-only-vlan-tagged ingress-filtering=yes name=BRIDGE-internal vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=sssssssss
set [ find default-name=ether3 ] comment=biuro1
set [ find default-name=ether4 ] comment=biuro2
set [ find default-name=ether5 ] comment=stacja
/interface pppoe-client
add add-default-route=yes comment=WAN disabled=no interface=ether1 name=pppoe-out password=SssssssssSSSSSS user=SssssssssSSSS
/interface vlan
add comment=sssssssss interface=BRIDGE-internal name=INTF-vlan5 vlan-id=5
add comment="GGG sala" interface=BRIDGE-internal name=INTF-vlan10 vlan-id=10
add comment="GGG biuro" disabled=yes interface=BRIDGE-internal name=INTF-vlan20 vlan-id=20
add comment="GGG audio" disabled=yes interface=BRIDGE-internal name=INTF-vlan30 vlan-id=30
add arp=reply-only comment=guest interface=BRIDGE-internal name=INTF-vlan90 vlan-id=90
add name=WAN
add name=LAN
add name=VLANs
add name=VPN
add include=LAN,VPN,VLANs name=Admin-Access
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=sssssssss-AES supplicant-identity="" wpa-pre-shared-key=sssssssss wpa2-pre-shared-key=sssssssss
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n basic-rates-a/g=12Mbps,18Mbps,24Mbps basic-rates-b=11Mbps disabled=no distance=indoors mode=ap-bridge security-profile=\
sssssssss-AES ssid=SSSSSSSSS supported-rates-b=11Mbps tx-power=14 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wps-mode=push-button-virtual-only
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee country=poland disabled=no distance=indoors frequency=5580 mode=ap-bridge security-profile=\
sssssssss-AES ssid=SSSSSSSSS wireless-protocol=802.11 wps-mode=push-button-virtual-only
add keepalive-frames=disabled mac-address=BA:69:F4:18:B0:E6 master-interface=wlan1 multicast-buffering=disabled name=wlan3-guest ssid=SSSS-gosc vlan-id=90 wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
add interface=BRIDGE-internal name=defconf
/ip hotspot profile
add dns-name=hotspot.GGG hotspot-address=10.1.90.1 html-directory=flash/hotspotGGG login-by=cookie,http-chap,http-pap,trial name=hsprof1
/ip hotspot user profile
add name=guest rate-limit=5M/2M shared-users=20
add name=dhcp_pool5 ranges=10.0.0.100-10.0.0.199
add name=dhcp_pool10 ranges=10.1.10.100-10.1.10.199
add name=dhcp_pool90 ranges=10.1.90.150-10.1.90.250
add name=dhcp_pool30 ranges=10.1.30.100-10.1.30.199
add name=dhcp_pool20 ranges=10.1.20.100-10.1.20.199
add address-pool=dhcp_pool5 disabled=no interface=INTF-vlan5 lease-time=1d name=dhcp5
add address-pool=dhcp_pool10 disabled=no interface=INTF-vlan10 lease-time=1d name=dhcp10
add add-arp=yes address-pool=dhcp_pool90 disabled=no interface=INTF-vlan90 lease-time=12h name=dhcp90
add address-pool=dhcp_pool30 disabled=no interface=INTF-vlan30 lease-time=1d name=dhcp30
add address-pool=dhcp_pool20 disabled=no interface=INTF-vlan20 lease-time=1d name=dhcp20
/ip hotspot
add address-pool=dhcp_pool90 disabled=no interface=INTF-vlan90 name=hotspot1 profile=hsprof1
add bridge=BRIDGE-internal interface=ether2 pvid=5
add bridge=BRIDGE-internal interface=ether3 pvid=5
add bridge=BRIDGE-internal interface=ether4 pvid=5
add bridge=BRIDGE-internal interface=ether5
add bridge=BRIDGE-internal interface=wlan1 pvid=5
add bridge=BRIDGE-internal interface=wlan2 pvid=5
add bridge=BRIDGE-internal ingress-filtering=yes interface=wlan3-guest pvid=90
set discover-interface-list=all
/interface bridge vlan
add bridge=BRIDGE-internal tagged=ether5,BRIDGE-internal untagged=ether2,ether3,ether4,wlan1,wlan2 vlan-ids=5
add bridge=BRIDGE-internal tagged=ether5,BRIDGE-internal vlan-ids=10
add bridge=BRIDGE-internal tagged=ether5,BRIDGE-internal vlan-ids=20
add bridge=BRIDGE-internal tagged=ether5,BRIDGE-internal vlan-ids=30
add bridge=BRIDGE-internal tagged=ether5,BRIDGE-internal untagged=wlan3-guest vlan-ids=90
add bridge=BRIDGE-internal untagged=ether4 vlan-ids=1
add interface=BRIDGE-internal list=LAN
add interface=ether1 list=WAN
add interface=INTF-vlan5 list=VLANs
add interface=INTF-vlan10 list=VLANs
add interface=INTF-vlan20 list=VLANs
add interface=pppoe-out list=WAN
add list=VPN
add address=192.168.88.1/24 disabled=yes interface=BRIDGE-internal network=192.168.88.0
add address=10.0.0.1/24 interface=INTF-vlan5 network=10.0.0.0
add address=10.1.10.1/24 interface=INTF-vlan10 network=10.1.10.0
add address=10.1.20.1/24 interface=INTF-vlan20 network=10.1.20.0
add address=10.1.30.1/24 interface=INTF-vlan30 network=10.1.30.0
add address=10.1.90.1/24 interface=INTF-vlan90 network=10.1.90.0
add address=192.168.1.88/24 disabled=yes interface=BRIDGE-internal network=192.168.1.0
add address=10.60.0.10/28 disabled=yes network=10.60.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
add address=10.1.1.99 comment="MC562 printer" disabled=yes mac-address=00:25:36:AE:AC:CF
add address=10.0.0.10 client-id=1:0:80:92:8c:7b:a7 comment="drukarka sssssssss" mac-address=00:80:92:8C:7B:A7 server=dhcp5
add address=10.1.10.10 client-id=1:8:5b:d6:d0:4f:a3 mac-address=08:5B:D6:D0:4F:A3 server=dhcp10
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1
add address=10.1.10.0/24 dns-server=10.1.10.1 gateway=10.1.10.1
add address=10.1.20.0/24 dns-server=10.1.20.1 gateway=10.1.20.1
add address=10.1.30.0/24 dns-server=10.1.30.1 gateway=10.1.30.1
add address=10.1.90.0/24 dns-server=10.1.90.1 gateway=10.1.90.1
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes cache-max-ttl=4d servers=1.1.1.1,1.1.1.2
/ip dns static
/ip firewall address-list
add address=acme-v02.api.letsencrypt.org list=Letsencrypt
add address=acme-staging-v02.api.letsencrypt.org list=Letsencrypt
add address=letsencrypt.org list=Letsencrypt
add action=accept chain=forward comment="allow mgmt-mgmt" dst-address=10.0.0.0/28 src-address=10.1.10.0/28
add action=accept chain=input dst-port=80 in-interface-list=WAN protocol=tcp src-address-list=Letsencrypt
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="## to remove ## accept all" disabled=yes
add action=accept chain=input dst-port=53 protocol=udp
add action=accept chain=input comment="from inside only" dst-port=80,8291,99 in-interface-list=Admin-Access protocol=tcp
add action=accept chain=input comment=ssh dst-port=22,99 protocol=tcp
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="drop all not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=fasttrack connection-state=established,related
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=10.1.90.0/24
add action=masquerade chain=srcnat comment="masq mgmt" dst-address=10.0.0.0/28 src-address=10.1.10.0/28
/ip hotspot user
set [ find default=yes ] limit-bytes-total=500000000 limit-uptime=1h
add name=admin password=ttttt
add name=guest password=guest profile=guest server=hotspot1
add name=gosc password=gosc profile=guest server=hotspot1
set [ find default=yes ] mac-cookie-timeout=8h parent-queue=*5 rate-limit=3M/1M shared-users=50
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=gggggggggg.pl
/ip hotspot walled-garden ip
add action=accept comment="kiosk radio" disabled=yes dst-address=10.1.90.0/24 !dst-address-list !dst-port !protocol server=hotspot1 src-address=10.1.90.2 !src-address-list
add action=accept comment=mmmmm disabled=no dst-address=mmmmm !dst-address-list !dst-port !protocol !src-address !src-address-list
add action=accept disabled=no dst-address=10.1.90.1 !dst-address-list !dst-port protocol=icmp !src-address !src-address-list
/ip service
set telnet disabled=yes
set ssh port=99
set www-ssl certificate=letsencrypt-autogen_2023-09-15T13:32:00Z disabled=no
/ip ssh
set always-allow-password-login=yes forwarding-enabled=both
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=MTmain
/system logging
add topics=hotspot,debug
add disabled=yes topics=dhcp
/system ntp client
set enabled=yes primary-ntp=91.149.253.184 secondary-ntp=162.159.200.123
/system package update
set channel=long-term
/system scheduler
add interval=3h name=duckdns on-event=duckdns policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=sep/15/2023 start-time=16:00:00
add name=ddns-reboot on-event=duckdns policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
add interval=11w3d name=letsencrypt on-event=test policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=sep/15/2023 start-time=00:03:12
add interval=3h name=noip on-event=no-ip.pl policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=sep/16/2023 start-time=16:00:00
/system script
/tool graphing interface
add interface=pppoe-out store-on-disk=no
add interface=INTF-vlan5 store-on-disk=no
add interface=INTF-vlan10 store-on-disk=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name=MTma filter-interface=INTF-vlan90 memory-limit=200KiB
MT hAC cfg
[admin@MT wAPac] > export
# nov/05/2023 13:48:15 by RouterOS 6.49.10
# software id = YLFH-8B7F
# model = RBwAPG-5HacD2HnD
add admin-mac=48:A9:8A:65:7F:9C auto-mac=no name=bridgeINT vlan-filtering=yes
set [ find default-name=ether1 ] comment="external INT"
set [ find default-name=ether2 ] comment="internal INT"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=poland disabled=no distance=indoors frequency=2437 installation=indoor mode=ap-bridge ssid=GGG-guest \
wireless-protocol=802.11 wps-mode=disabled
add keepalive-frames=disabled mac-address=4A:A9:8A:65:7F:9D master-interface=wlan1 multicast-buffering=disabled name=wlan1-2 ssid=MT-guest vlan-id=90 wds-cost-range=0 \
/interface vlan
add interface=ether1 name=VLAN1 vlan-id=1
add interface=ether1 name=VLAN5 vlan-id=5
add interface=ether1 name=VLAN10 vlan-id=10
add interface=ether1 name=VLAN20 vlan-id=20
add interface=ether1 name=VLAN30 vlan-id=30
add interface=ether1 name=VLAN90 vlan-id=90
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk comment="WPA2 lllllll4321" mode=dynamic-keys name=sec-lllllll321 supplicant-identity="" wpa2-pre-shared-key=lllllll321
add authentication-types=wpa2-psk mode=dynamic-keys name=sec-214 supplicant-identity="" wpa2-pre-shared-key=214-BBBBBB
add authentication-types=wpa2-psk mode=dynamic-keys name=LLLLLL supplicant-identity="" wpa2-pre-shared-key=79-LLLLLL
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country="united states" distance=indoors frequency=5745 installation=indoor mode=ap-bridge \
security-profile=sec-214 ssid=GGG wireless-protocol=802.11
add keepalive-frames=disabled mac-address=4A:A9:8A:65:7F:9E master-interface=wlan2 multicast-buffering=disabled name=wlan2-2 ssid=GGG-guest vlan-id=90 wds-cost-range=0 \
add keepalive-frames=disabled mac-address=4A:A9:8A:65:7F:9F master-interface=wlan1 multicast-buffering=disabled name=wlan3 security-profile=LLLLLL ssid=GLOS_NA_PUSTYNI2 \
vlan-id=5 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add interface=bridgeINT name=dhcp0
add add-arp=yes interface=wlan1-2 lease-time=30m name=dhcp3
/ip hotspot
add interface=wlan1-2 name=hotspot1
set [ find default=yes ] rate-limit=2M/500k shared-users=20
add name=guest-prof rate-limit=4M/2M shared-users=20
add name=vip-prof rate-limit=50M/10M shared-users=5
add bridge=bridgeINT interface=ether2
add bridge=bridgeINT interface=wlan1 pvid=90
add bridge=bridgeINT interface=wlan2 pvid=10
add bridge=bridgeINT ingress-filtering=yes interface=wlan1-2 pvid=90
add bridge=bridgeINT ingress-filtering=yes interface=ether1
add bridge=bridgeINT ingress-filtering=yes interface=wlan2-2 pvid=90
add bridge=bridgeINT tagged=ether1 vlan-ids=5
add bridge=bridgeINT tagged=ether1 untagged=wlan2 vlan-ids=10
add bridge=bridgeINT disabled=yes tagged=ether1 vlan-ids=20
add bridge=bridgeINT tagged=ether1 untagged=wlan1,wlan2-2 vlan-ids=90
add bridge=bridgeINT disabled=yes tagged=ether1 vlan-ids=30
add bridge=bridgeINT disabled=yes untagged=ether1,ether2 vlan-ids=1
add independent-learning=yes ports=ether2 switch=switch1 vlan-id=20
add independent-learning=yes ports=ether2 switch=switch1 vlan-id=30
add independent-learning=yes ports=ether2 switch=switch1 vlan-id=10
add interface=bridgeINT list=LAN
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridgeINT network=192.168.88.0
add address=10.1.20.3/24 interface=VLAN20 network=10.1.20.0
add address=10.1.10.3/24 interface=VLAN10 network=10.1.10.0
add address=192.168.1.222/24 disabled=yes interface=bridgeINT network=192.168.1.0
add address=10.0.0.3/24 interface=VLAN5 network=10.0.0.0
add address=10.1.30.3/24 interface=VLAN30 network=10.1.30.0
add address=10.60.0.11/28 network=10.60.0.0
add address=10.1.90.3/24 interface=VLAN90 network=10.1.90.0
/ip cloud
/ip dhcp-client
add interface=VLAN1
add address=10.5.50.0/24 comment="hotspot network" gateway=10.5.50.1
set allow-remote-requests=yes servers=10.0.0.1,1.1.1.1
/ip dns static
add action=accept chain=input comment="test - disable" disabled=yes
add action=accept chain=forward comment="test - disable" disabled=yes
add action=accept chain=forward comment="ALLOW ALL FORWARD - TEST" disabled=yes
add action=accept chain=input dst-port=8291,80,22 protocol=tcp
add action=accept chain=input disabled=yes dst-port=22 in-interface=*E protocol=tcp
add action=accept chain=input comment="ALLOW ALL INPUT - TEST" disabled=yes
add action=drop chain=input comment="defconf: drop invalid /////" connection-state=invalid
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=yes src-address=10.5.50.0/24
add action=accept chain=srcnat disabled=yes out-interface=*E
/ip hotspot user
add name=admin password=tttttttt
add limit-bytes-total=600000000 limit-uptime=2h name=gosc profile=guest-prof
add name=vip password=GGG.vip
add distance=1 gateway=10.0.0.1
/system clock
/system identity
set name="MT wAPac"
/system logging
add topics=dhcp,debug
add disabled=yes topics=debug
add topics=wireless,debug
set channel=testing
add interface=VLAN90 store-on-disk=no
/tool mac-server
/tool sniffer
set file-name=wap filter-interface=wlan1 memory-limit=200KiB
connection : MT main ether 5 – switch — MT hAC ether 1
testing guest on VLAN90 – wifi1 on MT hAC interface…
