DHCP relay and external Linux DHCP server
I have a problem with my setup. I am trying to use external DHCP server for local wi-fi clients. Server is configured and start isc-dhcp-server process without errors. When wi-fi client connects it does not recieve IP address. DHCP relay status shows that requests are counting and increasing but responses are zero.
DHCP server is on 10.0.2.2/24
Mikrotik is on same LAN 10.0.2.1/24
Interface wan is wired with Linux server through switch.
/ip dhcp-relay> print
 #   NAME               INTERFACE               DHCP-SERVER     LOCAL-ADDRESS
 0   relay1             wifbridge          10.0.2.2        0.0.0.0
/ip address> print
 #   ADDRESS            NETWORK         INTERFACE
 0   10.10.10.1/22      10.10.8.0       wifibridge
 2   10.0.2.10/24       10.0.2.0        wan
/ip route> print
 0 A S  0.0.0.0/0                          wan                       1
 1 ADC  10.0.2.0/24        10.0.2.10       wan                       0
 2 ADC  10.10.8.0/22       10.10.10.1      wifibridge            0
/ip firewall nat> print
1   chain=srcnat action=masquerade out-interface=wan
 /ip firewall filter> print
13   chain=input action=accept src-address=10.0.1.0/24
14   chain=input action=accept src-address=10.0.2.0/24
18   chain=forward action=accept dst-address=10.0.2.2
I can ping Linux box with DHCP server from mikrotik router. Linux log says that it is receiving requests and offering IP address.
What am I missing here? Some firewall rules or routes?
THX
Did you set a static route to 10.10.8.0/22 on your linux box? Additionally I would set the local address of your relay to 10.10.10.1
SwissWISP I did as you suggested. I set relay local address to 10.10.10.1.
And added static route to Linux. I hope it is correct.
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.0.2.1        0.0.0.0         UG    100    0        0 eth0
10.0.2.0        *               255.255.255.0   U     0      0        0 eth0
10.10.8.0       10.0.2.1        255.255.252.0   UG    0      0        0 eth0
And I can ping 10.10.10.1 from Linux server. But still not receiving IP. Should I add some special DST-NAT rule?
First you should check if basic connectivity works. So assign a static IP to a host (no via DHCP) and check if the connectivity is OK. A second thing you should check is, if connection tracking in the firewall is active.
I must say, that I never used dhcp-relay over a “nated” Router, but basically this should work.
Hello again! I am back after weekend. I checked that connection tracking is enabled and is on auto mode. Also opened firewall and all input and forward traffic is allowed without conditions. I checked that I can ping remote DHCP from router, same is from DHCP server to DHCP Relay local address. But still not working, requests are counting but responses is zero. I can of course bridge all interfaces together and try if setup works, but my technical goal and requirement is to use remote DHCP server because I will have several wireless hotspots and I want to enable client roaming. Could somebody from Mikrotikls help me here if reading ?
Any good ideas are welcomed from community too.
Hello, Probably its due to the rules in your iptables, your might got traffic forwarded. (instead hiting input chain.)
could you please do a “iptables -nvL” and post the result here for further analysing?
COuld you please check your iptables.
Thansk for support. It is fresh Ubuntu LTS server so I believe all traffic is open. But I will post iptables later when I get this box switched on.
hello did you resolve your problem? i test the same scenario and doesn’t work at first test, so i increment the “delay threshold” and works fine
