I need to monitoring responses in dhcp-relay. If amount of responces=0 in 1 minute, router should be rebooted
I need somthing like:
:delay 1m
/ip dhcp-relay monitor relayname once
:if ([responses] = 0) do={/system reboot;};
Who can help me please
:delay 1m
check this
:local resp
/ip dhcp-relay monitor 0 do={
:set resp ( responses) } once;
:if ($resp = 0 ) do={
/system reboot;}
c0d3rSh3ll thank you very much +1 ![]()
and maybe you can add…
if responses = 0 and if requests > 0
:local resp;
:local req
:set resp ( responses);
:set req (requests );
} once;
:if [ ($resp = 0 ) && ($req > 0)] do={
/system reboot;
}some other thing? ![]()
c0d3rSh3ll you are the best ![]()
if requests more 50 than responses (example req 1500 resp 400)
:if [ ($req - $resp > 50)] ??
