DHCP server cannot run on slave interface
I have DHCP server on this VLAN interface. When I try to configure this Vlan interface on bridge. DHCP server stops working. it says DHCP server can not run on slave interface.
My configuration are bellow
add name=ACCESS_999
add name=LAN
/interface vlan
add interface=LAN name=VLAN_101 vlan-id=101
add interface=LAN name=VLAN_201 vlan-id=201
add interface=LAN name=VLAN_999 vlan-id=999
add name=dhcp_pool1 ranges=10.2.100.2-10.2.100.254
add name=dhcp_pool2 ranges=10.2.96.2-10.2.96.254
add name=dhcp_pool3 ranges=10.2.99.2-10.2.99.254
add address-pool=dhcp_pool1 interface=VLAN_101 name=DHCP_VLAN_101
add address-pool=dhcp_pool2 interface=VLAN_201 name=DHCP_VLAN_201
DHCP server can not run on slave interface!
add address-pool=dhcp_pool3 interface=VLAN_999 name=DHCP_VLAN_999
add bridge=ACCESS_999 interface=ether2
add bridge=ACCESS_999 interface=VLAN_999
add address=10.2.96.1/24 interface=VLAN_201 network=10.2.96.0
add address=10.2.100.1/24 interface=VLAN_101 network=10.2.100.0
add address=10.2.99.1/24 interface=VLAN_999 network=10.2.99.0
add address=10.2.96.0/24 dns-server=8.8.8.8,10.2.99.1 gateway=10.2.96.1
add address=10.2.99.0/24 dns-server=8.8.8.8,10.2.99.1 gateway=10.2.99.1
add address=10.2.100.0/24 dns-server=8.8.8.8,10.2.99.1 gateway=10.2.100.1
(1) A vlan cannot be a bridge port normally its etherports and wlans…
(2) Additionally you assigned vlan 99 to the LAN bridge, then trying to associate vlan 99 to the ACCESS_999 bridge
methinks you are confused!!!
First why 2 bridge and using vlan? As a newbie I’ve been there long time ago, always make 2 bridge (or more zZz) just to make another netwok segment.
Now with vlan no need many bridge anymore, just one and next can create more than one network segment.
add name=ACCESS_999
add name=LAN
Just one bridge then put all your ethernet port into that single bridge.. Let say you choose to use only LAN bridge, delete the ACCESS_999 bridge entry.
<= as anav mention this make that error about slave. Only entry ethernet port and/or wlan with corresponding match pvid.
since u delete ACCESS_999 bridge, change it to
add bridge=LAN interface=ether2
/interface vlan
The rest I think you must know about tagged and untagged, firewall etc. You can read nice tutorial here http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
Your config above not complete.
