Hello all,
how this is working? Is DHCP-Option 15?
/ip dhcp-server network set [find] domain="internal"
I would like to ping “device hostname”.domain without adding as DNS Static.
Not sure if Domain= should be the router (eg.: router.lan) or the local domain (like .internal / .lan / home.arpa)
Domain is domain name … without leading dot. So if your host names are e.g. “host.my.domain.tld”, then you should set domain property of DHCP server network entries to domain=my.domain.tld
This setting sets DHCP Option 15 (the domain name that client should use as suffix when resolving hostnames via the Domain Name System) … and it’s entirely up to clients on how they use them. Definitely nothing to do with DHCP server or DHCP client.
So normally yes, <my.domain.tld> can be “home.arpa” or “local” (not sure about the later, some OSes have problems with domain names which don’t contain at least one dot).
