dhcp server per host
I want to assign to some hosts (with stable eth address) IPs from different network(s). VLANs based on switch port is not an option. What’s possible?
Enter DHCP leases for any particular vlan and enter in an IP and mac address manually if that is what you mean?
Otherwise after entering DHCP leases and you see an IP address that you want the lease to be fixed, select MAKE STATIC.
I did make the lease static, give it proper IP, but totally forgot to set-up the network in the networks tab so god knows what gateway, dns, etc. the client got and naturally “it does not work”
thanks.
Every error here I have made and seen… the harder ones are the more basic ones.
192.168.5.0/24 for IP address OR
192.168.5.1/24 for dhcp server network
