Trying to convert DHCP services from wifi router to my new MikroTik router.
I have defined two zones, with zone options. One on each VLAN
Test VLAN is 101. And I swear it worked for a while, now it stopped responding. Trying to figure out where I can get logs from on router side to find what is going on. I know the VM is on the VLAN L2 as I can ping when set to static IP and arp table shows on local broadcast domain. DHCP client times out due to lack of response from “server”.
Questions:
- Where is logs from switch that I can check service started and response to client request
- I assume with each VLAN being bound with IP (for routing) I assume no relay definition needed as the router interfaces is on that native VLAN.
3 If / when I can purchase second switch, Is there any comments on zone split option to create this kind of service HA
sw3_20191031.txt (37 KB)
