Hi - I am a novice setting up a routerboard and I am attempting to create 3 VLANs which each have a DHCP server providing IPs from a pool.
This is the tutorial I watched to do the setup: https://youtu.be/pdpFAxwocTo
The router has the default 192.168.100.0/24 (changed 3rd octet from 88 to 100) and I created 2 additional VLANs 10.1.50.0/24 and 172.16.66.0/24 which should be tied to ethernet 2 port.
When I plug in a device to the router, I get a DHCP 192.168.88.x address and can ping the 10.1.50.1 and 172.16.66.3 gateway IPs, but when I try to set a static IP on the 10.1.50.x or 172.16.66.x addresses, I can not ping their gateways nor the 192.167.88.x
My configuration is pasted below. Looking for where I may be off to have ability to use the VLANs. Thank you.
Note I read the guide 'Using RouterOS to VLAN your network http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
I think the pattern it speaks to I’m after is the ‘all in one’ configuration.
# jan/02/1970 00:54:40 by RouterOS 6.48.2
# software id = E6GF-Z7TE
# model = RB750Gr3
# serial number = [redacted]
add admin-mac=C4:AD:34:EE:4E:A4 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether2 name=VLAN10 vlan-id=10
add interface=ether2 name=VLAN20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.100.10-192.168.100.254
add name=dhcp_pool1 ranges=10.1.50.100-10.1.50.110
add name=dhcp_pool2 ranges=172.16.66.100-172.16.66.110
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=VLAN10 name=dhcp_vlan1
add address-pool=dhcp_pool2 disabled=no interface=VLAN20 name=dhcp_vlan2
add bridge=bridge interface=ether2
add address=192.168.100.1/24 comment=defconf interface=bridge network=\
192.168.100.0
add address=10.1.50.1/24 interface=VLAN10 network=10.1.50.0
add address=172.16.66.3/24 interface=VLAN20 network=172.16.66.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.1.50.0/24 comment=#test dns-server=9.9.9.9 gateway=10.1.50.1 \
netmask=24
add address=172.16.66.0/24 comment=test2 dns-server=9.9.9.9 gateway=\
172.16.66.3 netmask=24
add address=192.168.100.0/24 comment=defconf gateway=192.168.100.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.100.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
ipsec-policy=out,none log=yes out-interface-list=WAN
/system identity
set name=MikroTikLab
/tool mac-server
/tool mac-server mac-winbox
