DHCPv6 over PPPoE: "DUID-LL length should be 10" with Huawei AX2 — RouterOS 7.24.6
Hello everyone,
I am investigating repeated DHCPv6 errors on a production PPPoE concentrator:
can't add dual-stack queue: DUID-LL length should be 10
Environment
  • MikroTik CCR2116-12G-4S+
  • RouterOS 7.24.6 long-term
  • PPPoE authentication and subscriber rate limits supplied through RADIUS
  • Dynamic DHCPv6-PD servers created by PPPoE
  • /64 prefixes delegated to subscribers
One affected client is a Huawei WiFi AX2, firmware 2.0.0.322(SP1C947).
Its current DHCPv6-PD binding shows:
duid=0x000302003c724bb7a0f959ad
iaid=246
ia-type=pd
status=bound
The client DUID is 12 bytes long. The following error is logged for its delegated prefix:
What we have verified
  • Prefix delegation succeeds.
  • Devices behind the Huawei have bidirectional IPv6 connectivity, including established TCP connections.
  • These connections are not using IPv6 NAT on the border router.
  • A dynamic simple queue already targets the subscriber’s PPPoE interface.
  • IPv6 throughput against the configured queue limit has not yet been tested.
Troubleshooting performed
We switched the Huawei WAN IPv6 address acquisition mode from DHCPv6 to SLAAC and reconnected PPPoE.
The WAN then received an address from a separate /64, while DHCPv6-PD continued providing the LAN prefix. However, the same queue error occurred again.
Attempts to set allow-dual-stack-queue=no on the affected binding and DHCPv6 server were rejected:
failure: Cannot modify dynamic bindings!
failure: can't edit dynamic object
Similar errors appear for several subscriber prefixes.
Questions
  1. Has anyone encountered this DUID format with Huawei routers?
  2. Is there a supported way to disable dual-stack queue association on DHCPv6 servers dynamically created by PPPoE?
  3. Does this error affect IPv6 rate limiting through the existing PPPoE interface queue, or only DHCP dual-stack queue association?
  4. Is there a known fix or recommended workaround?
I can provide additional sanitized command output. A supout.rif file can be supplied privately to MikroTik Support.
Thank you.
Seems to be a problem with client as it sends malformed package not compatibile with RFC.
Mikrotik made some changes to DHCP lately to follow RFCs and do not accept bad data.
Maybe the Huawei client should be "fixed"?
