Disable all simple queue!
Hi All.. all my clients are PPPOE and the bandwith for each one is restricted by simple queue and scripts, all is good..
I’m woundering if there is a script that disable all simple queue at night?
Thank u all
/queue simple disable [/queue simple find]
/queue simple enable [/queue simple find]
And then schedule those at the times you want to run them. The manual on the scheduler shows how.
thanks for replying..
I have test it but it didn’t work, did u mean about [/queue simple find] the ‘‘queue name’’ or the target IP address, because i test both and i can see the script is counting on the ‘‘Run Count’’ but it did not disable all or any of the simple queues.
I’m, trying to disable all the simple queue not a single one,
can u give me an example pls!
Thanks again for replying
Waiting for your reply,
I meant exactly what I posted. Find without parameters returns all queues.
paste exactly what Fewi posted, don’t change anything! Copy and paste
Ok .. All is Good
Thank u Guys! :slight_smile:
