I have an AdGuard Home v0.107.53 container that is pointing to an Unbound instance.
It is running on a Mikrotik RB5009UPr.
AdGuard uses a static IPv6 local address and Unbound has an ACL to allow AdGuard’s queries.
However, the AdGuard container also gets a SLAAC IPv6 from the network. So it ends up with 3 IPv6 addresses, like this:
[RB5009] > interface/veth/print
0 R ;;; AdGuard Home container virtual interface
name="veth1_adguard" address=192.168.8.5/24,fd01:192:168:8::5/64 gateway=192.168.8.1
gateway6=fd01:192:168:8::1
# ip add show eth0
inet 192.168.8.5/24 scope global eth0
valid_lft forever preferred_lft forever
inet6 fd01:192:168:8:ecb2:17ff:fe94:cbd7/64 scope global dynamic flags 100 ## unecessary
valid_lft 2591960sec preferred_lft 604760sec
inet6 fd01:192:168:8::5/64 scope global
inet6 fe80::ecb2:17ff:fe94:cbd7/64 scope link
Whenever the container is rebooted, it gets a different IPv6 from RA.
This causes some queries from AdGuard to Unbound to fail due to the static ACL.
I would like to disable this IPv6 addressing based on router advertisements on this container, and keep only the static one, but could not find such a configuration.
I’ve downloaded the Adguard Home container from the Docker registry and I’m using the “lastest” tag, which uses the Alpine distribution. It doesn’t have SystemD.
# ip add show eth0
valid_lft 2591680sec preferred_lft 604480sec
So far, I’ve found that when Unbound receives queries, it is receiving on its static IPv6 (fd01:192:168:8::7), but is answering from its SLAAC address. I think this is what is causing the queries to fail.
Currently, RouterOS neighbor discovery is set to “all” interfaces. I thought about changing it to specific interfaces, but the AdGuard and Unbound containers are part of the same VLAN that other clients use, so that doesn’t seem to help.
