Disable WLan Interface with button on CAP AC with CAPsMAN
Hi
I want to use the buttons on the Cap AC to enabled/disable WLan. The ACs are managed by CAPsMAN from a HEX router.
Because of that If I want to disable wlan1 or 2 by script on the device it says “failure: interface managed by CAPsMAN”
How must the script look like? Do I need one per AC to access CAPsMAN and enable/disable it from there?
Can I access the routerboard of the managed ACs via CAPsMAN to programm scripts centrally?
Thanks for your help in advnce!
any idea? is it not possible?
I wrote the following script for the same purpose. It’s working fine for some time now. Still working on 6.48.
:log info message=("mode button was pressed");
:local i
:if ([/int wir cap get enabled] = true) do={
  /interface wireless cap set enabled=no;
  :if ( [/int wir get 0 disabled ] = false ) do={
    :foreach i in= [ /int wir find ] do={ :int wir disable $i };
} else={
  /interface wireless cap set enabled=yes
You can also find it on my github gists: https://gist.github.com/sebastian13/5655efab2b51f0f3572352acbb640c48
