Disk Full
Hi, I have RB433 working with UserManager. When disk is full It doesn´t work. How can I get free space? I´ve tried to delete logs but I get an error. Thanks.
It could be that console is showing timeouts, you need to wait for a while, when logs will be deleted. It should free disk space (alternatively you can clear logs from Web Interface).
We suggest to use external drive for saving User Manager database.
And Next time if it is not important to you disable logs so it does not eat up all of your disk space on your RB433 Or get an external hard drive for UM.
Same problem here, did you find a fix, i have deleted 10 logs at a time (more than that seems to fail) untill i had enough space to turn logging off on all of my routers.
Any help from anyone else?
Cheers
