Dmitry on firewalling ip firewall mangle
hi,
I was testing the folowing config http://wiki.mikrotik.com/wiki/Dmitry_on_firewalling, and their were some questions about mangle and services configuration on the example, that i’m having some trouble to understand.
The config is almost the same except instead of a transparent proxy i’m using a srcnat masquerade.
The config works well but when i tried to add a new config on mangle services for openpvn, they all got dropped
by other-udp rule on the filter. so (i guess they are not been marked correctly?).
The connection is openvpn client opend by workstation → router OS → internet.
Thanks in advanced.
