Below you can see my entire export script. Pinging IP Addresses works, but resolving DNS does not. I don't see what I'm doing wrong, please help ![]()
add comment=genconf name=bridge protocol-mode=mstp vlan-filtering=yes
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add comment=management interface=bridge name=ADMIN vlan-id=10
add interface=bridge name=APP vlan-id=40
add interface=bridge name=FAMILY vlan-id=20
add interface=bridge name=GUEST vlan-id=50
add interface=bridge name=JAIL vlan-id=60
add interface=bridge name=VPN vlan-id=30
add comment=genconf name=WAN
add comment=genconf name=LAN
/interface wifi channel
add band=2ghz-ax name=ch-2ghz width=20mhz
add band=5ghz-ax name=ch-5ghz skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi datapath
add bridge=bridge name=dp-vlan20 vlan-id=20
add bridge=bridge client-isolation=yes name=dp-vlan50-iso vlan-id=50
add bridge=bridge client-isolation=yes name=dp-vlan60-iso vlan-id=60
/interface wifi security
add authentication-types=wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes name=sec-home-34-family wps=disable
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes name=sec-home-34-guest wps=push-button
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes name=sec-home-34-jail wps=push-button
/interface wifi configuration
add channel=ch-2ghz country=Germany datapath=dp-vlan20 mode=ap name=cfg-home-34-family-24ghz security=sec-home-34-family ssid=\
home.34.FAMILY
add channel=ch-5ghz country=Germany datapath=dp-vlan20 mode=ap name=cfg-home-34-family-5ghz security=sec-home-34-family ssid=\
home.34.FAMILY
add channel=ch-2ghz country=Germany datapath=dp-vlan50-iso mode=ap name=cfg-home-34-guest-24ghz security=sec-home-34-guest ssid=\
home.34.GUEST
add channel=ch-5ghz country=Germany datapath=dp-vlan50-iso mode=ap name=cfg-home-34-guest-5ghz security=sec-home-34-guest ssid=\
home.34.GUEST
add channel=ch-2ghz country=Germany datapath=dp-vlan60-iso mode=ap name=cfg-home-34-jail-24ghz security=sec-home-34-jail ssid=\
home.34.JAIL
add channel=ch-5ghz country=Germany datapath=dp-vlan60-iso mode=ap name=cfg-home-34-jail-5ghz security=sec-home-34-jail ssid=\
home.34.JAIL
add name=pool-ADMIN ranges=10.0.10.10-10.0.10.254
add name=pool-FAMILY ranges=10.0.20.10-10.0.20.254
add name=pool-VPN ranges=10.0.30.10-10.0.30.254
add name=pool-APP ranges=10.0.40.10-10.0.40.254
add name=pool-GUEST ranges=10.0.50.10-10.0.50.254
add name=pool-JAIL ranges=10.0.60.10-10.0.60.254
add address-pool=pool-ADMIN interface=ADMIN lease-time=1d name=dhcp-ADMIN
add address-pool=pool-FAMILY interface=FAMILY lease-time=1d name=dhcp-FAMILY
add address-pool=pool-VPN interface=VPN lease-time=1d name=dhcp-VPN
add address-pool=pool-APP interface=APP lease-time=1d name=dhcp-APP
add address-pool=pool-GUEST interface=GUEST lease-time=1d name=dhcp-GUEST
add address-pool=pool-JAIL interface=JAIL lease-time=1d name=dhcp-JAIL
/certificate settings
set builtin-trust-store=all
/interface bridge filter
add action=drop chain=forward comment="genconf: IPv6 off, bridged frames the CPU forwards" mac-protocol=ipv6
add action=drop chain=input comment="genconf: IPv6 off, frames to the router" mac-protocol=ipv6
add bridge=bridge comment=genconf frame-types=admit-only-vlan-tagged interface=ether2
add bridge=bridge comment=genconf frame-types=admit-only-vlan-tagged interface=ether3
add bridge=bridge comment=genconf frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
add bridge=bridge comment=genconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=50
add bridge=bridge comment=genconf frame-types=admit-only-untagged-and-priority-tagged interface=sfp1 pvid=10
set tcp-established-timeout=1h
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=bridge comment="ADMIN and SFP" tagged=bridge untagged=ether4,sfp1 vlan-ids=10
add bridge=bridge comment=FAMILY tagged=bridge,ether3 vlan-ids=20
add bridge=bridge comment=VPN tagged=bridge vlan-ids=30
add bridge=bridge comment=APP tagged=bridge,ether2 vlan-ids=40
add bridge=bridge comment=GUEST tagged=bridge,ether3 untagged=ether5 vlan-ids=50
add bridge=bridge comment=JAIL tagged=bridge,ether3 vlan-ids=60
add comment=genconf interface=ether1 list=WAN
add comment=genconf interface=bridge list=LAN
add comment=genconf interface=ADMIN list=LAN
add comment=genconf interface=FAMILY list=LAN
add comment=genconf interface=VPN list=LAN
add comment=genconf interface=APP list=LAN
add comment=genconf interface=GUEST list=LAN
add comment=genconf interface=JAIL list=LAN
/interface wifi cap
set caps-man-addresses=127.0.0.1 certificate=request enabled=yes slaves-static=no
/interface wifi capsman
set enabled=yes interfaces=bridge require-peer-certificate=yes upgrade-policy=suggest-same-version
/interface wifi provisioning
add action=create-dynamic-enabled comment=2.4ghz master-configuration=cfg-home-34-family-24ghz name-format=cap-%I-24ghz \
slave-configurations=cfg-home-34-guest-24ghz,cfg-home-34-jail-24ghz supported-bands=2ghz-ax,2ghz-n,2ghz-g
add action=create-dynamic-enabled comment=5ghz master-configuration=cfg-home-34-family-5ghz name-format=cap-%I-5ghz \
slave-configurations=cfg-home-34-guest-5ghz,cfg-home-34-jail-5ghz supported-bands=5ghz-ax,5ghz-ac,5ghz-n
add address=10.0.10.1/24 comment=ADMIN interface=ADMIN network=10.0.10.0
add address=10.0.20.1/24 comment=FAMILY interface=FAMILY network=10.0.20.0
add address=10.0.30.1/24 comment=VPN interface=VPN network=10.0.30.0
add address=10.0.40.1/24 comment=APP interface=APP network=10.0.40.0
add address=10.0.50.1/24 comment=GUEST interface=GUEST network=10.0.50.0
add address=10.0.60.1/24 comment=JAIL interface=JAIL network=10.0.60.0
add address=10.0.0.1/24 comment=genconf interface=bridge network=10.0.0.0
/ip dhcp-client
add comment=WAN1 interface=ether1 name=client1 use-peer-ntp=no
add address=10.0.10.0/24 comment=ADMIN dns-server=10.0.10.1 gateway=10.0.10.1
add address=10.0.20.0/24 comment=FAMILY dns-server=10.0.20.1 gateway=10.0.20.1
add address=10.0.30.0/24 comment=VPN dns-server=10.0.30.1 gateway=10.0.30.1
add address=10.0.40.0/24 comment=APP dns-server=10.0.40.1 gateway=10.0.40.1
add address=10.0.50.0/24 comment=GUEST dns-server=10.0.50.1 gateway=10.0.50.1
add address=10.0.60.0/24 comment=JAIL dns-server=10.0.60.1 gateway=10.0.60.1
set allow-remote-requests=yes cache-size=4096KiB servers=9.9.9.9,149.112.112.112 use-doh-server=https://dns.quad9.net/dns-query \
verify-doh-cert=yes
/ip dns adlist
add ssl-verify=no url=https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
/ip dns static
add address=9.9.9.9 comment="bootstrap DoH" name=dns.quad9.net type=A
add address=149.112.112.112 comment="bootstrap DoH" name=dns.quad9.net type=A
/ip firewall address-list
add address=127.0.0.0/8 comment="genconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="genconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="genconf: RFC6890 documentation" list=bad_ipv4
add address=240.0.0.0/4 comment="genconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="genconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="genconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="genconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="genconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="genconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="genconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="genconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="genconf: RFC6890 benchmark" list=not_global_ipv4
add address=255.255.255.255 comment="genconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="genconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="genconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="genconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="genconf: RFC6890" list=bad_dst_ipv4
add action=accept chain=input comment="genconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="genconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="genconf: accept ICMP" protocol=icmp
add action=accept chain=input comment="genconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="drop DNS from WAN (no open resolver)" dst-port=53 in-interface-list=WAN protocol=udp
add action=drop chain=input comment="drop DNS from WAN (no open resolver)" dst-port=53 in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="management from ADMIN" in-interface=ADMIN
add action=accept chain=input comment="LAN: DNS, DHCP, NTP to router" dst-port=53,67,123 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="LAN: DNS tcp to router" dst-port=53 in-interface-list=LAN protocol=tcp
add action=drop chain=input comment="drop other LAN traffic to router (management VLAN only)" in-interface-list=LAN
add action=drop chain=input comment="genconf: drop all not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="genconf: accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="genconf: accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="genconf: fasttrack" connection-state=established,related
add action=accept chain=forward comment="genconf: accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="genconf: drop invalid" connection-state=invalid
add action=drop chain=forward comment="isolate APP: internet only" connection-state=new in-interface=APP out-interface-list=!WAN
add action=drop chain=forward comment="isolate GUEST: internet only" connection-state=new in-interface=GUEST out-interface-list=!WAN
add action=drop chain=forward comment="isolate JAIL: internet only" connection-state=new in-interface=JAIL out-interface-list=!WAN
add action=drop chain=forward comment="JAIL: no internet" in-interface=JAIL out-interface-list=WAN
add action=drop chain=forward comment="genconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
add action=redirect chain=dstnat comment="force LAN DNS through router" dst-address-type=!local dst-port=53 in-interface-list=LAN \
protocol=udp to-ports=53
protocol=tcp to-ports=53
add action=masquerade chain=srcnat comment="genconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ip firewall raw
add action=drop chain=prerouting comment="genconf: drop bogon IP's" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="genconf: drop bogon IP's" dst-address-list=bad_ipv4 in-interface-list=WAN
add action=drop chain=prerouting comment="genconf: drop bogon IP's" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="genconf: drop bogon IP's" dst-address-list=bad_dst_ipv4 in-interface-list=WAN
add action=drop chain=prerouting comment="genconf: drop non global from WAN" in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="genconf: drop bad UDP" port=0 protocol=udp
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
set winbox available-from=10.0.0.0/24,10.0.10.0/24
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall filter
add action=drop chain=input comment="genconf: IPv6 off, drop everything to the router"
add action=drop chain=forward comment="genconf: IPv6 off, drop everything routed"
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity
set name=Main
/system ntp client
set enabled=yes
/system ntp client servers
add address=ptbtime1.ptb.de
add address=ptbtime2.ptb.de
add address=ptbtime3.ptb.de
/system routerboard settings
set auto-upgrade=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
