I “just” installed a hAP ax2 board and so far almost everything is working perfectly. Using RouterOS 7.9 (stable)
I am left with one particularly annoying issue: DNS seems to be behaving strangely.
When entering static DNS entries, “router.lan” works, but “router” doesn’t. Any machine that connects to the network and advertises its computername gets registered just fine in DHCP leases, but its name is not propagated, even to router internally. Pinging the machine by its name does not resolve the name while IP works just fine.
Below’s my configuration (I removed static DHCP leases and NAT entries):
How can I make this work properly?
To be clear, I want to be able to “ping zabbix” and that would resolve to a machine identifying itself as zabbix, which is somewhere in the subnet. Right now all I can do is “ping 192.168.237.22”.
Please note that if I create a static DNS entry for “zabbix.lan”, that works as expected. But current setup just doesn’t.
My configuration:
may/23/2023 13:03:36 by RouterOS 7.9
software id = 9I26-0BUN
model = C52iG-5HaxD2HaxD
serial number = HE908GJ976M
add admin-mac=48:A9:8A:91:9E:1E auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=Slovenia .mode=ap .ssid=velis-office
disabled=no name=main-2,4 security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.country=Slovenia .mode=ap .ssid=velis-office
disabled=no name=main-5 security.authentication-types=wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=scantron.si datapath.bridge=bridge disabled=no mac-address=4A:A9:8A:91:9E:25 master-interface=
main-2,4 name=scantron-2,4 security.authentication-types=wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=scantron.si datapath.bridge=bridge disabled=no mac-address=4A:A9:8A:91:9E:24 master-interface=main-5
name=scantron-5 security.authentication-types=wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=velis-guest disabled=no mac-address=4A:A9:8A:91:9E:23 master-interface=main-2,4 name=guest-2,4
add configuration.mode=ap .ssid=velis-guest disabled=no mac-address=4A:A9:8A:91:9E:22 master-interface=main-5 name=guest-5
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.237.50-192.168.237.199
add address-pool=dhcp interface=bridge name=defconf
/interface bridge filter
add action=drop chain=forward comment=guest in-interface=guest-5
add action=drop chain=forward comment=guest out-interface=guest-5
add action=drop chain=forward comment=guest in-interface=guest-2,4
add action=drop chain=forward comment=guest out-interface=guest-2,4
add bridge=bridge comment=defconf interface=main-5
add bridge=bridge comment=defconf interface=main-2,4
add bridge=bridge interface=guest-5
add bridge=bridge interface=guest-2,4
add address=192.168.237.1/24 comment=defconf interface=bridge network=192.168.237.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.237.21 comment=remote mac-address=08:00:27:AC:9F:B0
add address=192.168.237.20 comment=“velis work” mac-address=3E:CA:6A:2E:8C:18
add address=192.168.237.0/24 comment=defconf dns-server=192.168.237.1 domain=lan gateway=192.168.237.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.237.1 comment=defconf name=router.lan
add address=192.168.237.2 name=klavora
add address=192.168.237.21 name=remote
add address=192.168.237.22 name=zabbix
add address=192.168.237.15 name=pbx
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=input comment=“WAN configuration” dst-port=80 protocol=tcp
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new
in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=33434-33534 protocol=udp
add action=accept chain=input comment=“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=udp src-address=
fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=input comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=input comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept established,related,untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1” hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=forward comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=forward comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
/snmp
set contact=Jure enabled=yes location=office trap-version=2
/system clock
set time-zone-name=Europe/Ljubljana
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
I have since found this post that seems to have the same issue:
http://forum.mikrotik.com/t/dns-accessing-local-machines-by-host-name/155576/1 (no resolution, just explanation)
