DNS-over-HTTPS and Unbound
I have an Unbound DoH server which I have tested working with a web browser and the included dohclient command. But its not working for Mikrotik. Has anyone come across anything incompatible with these?
I tried with 2 different devices running 6.48.6 LTS and 7.1 LTS.
In all cases it would resolve the DoH server name (according to dns cache print).
Did you add the certificate and NTP?
Yes to both, however, the certificate should only be required with verify-doh-cert=yes and I had it turned off while was trying to resolve this.
Does it work when you configure the DoH server by IP instead of by name?
No.
