are you trying to break things ? dns cache isn’t supposed to be statically entered and will cause major problems if it is. if you enter our IP addresses into your dns server as authoritative I will hunt you down and shake a stick at you : )
changeip,
I need script copy all the sites from the dns cache and adds it to dns static, I see it successful in http://forum.mikrotik.com/t/dns-script/12088/1 it seems to be in v2.9.X
now I try with v3.4 and nothing
After the copy I will filter the useful DNS addresses that is static for sites and not change periodically(like yahoo and Google),
I hope to make this similar to DNS server operation
So what the befits of static DNS option in MT ?
once you resolve google.com or yahoo.com they will be used just as a static address, however, they will be refreshed periodically. A static entry is used if they are your hostnames (or you want to disallow resolving certain names).
