Hi everyone, I would like to have my router to stop all the DNS coming from my clients and not reaching my ISP provider. Any idea?
To just block it:
/ip firewall filter add chain=forward in-interface=LAN protocol=udp dst-port=53 connection-state=new action=drop
To intercept it and redirect it to your own server:
/ip firewall nat add chain=dstnat in-interface=LAN protocol=udp dst-port=53 action=dst-nat to-address=IP.OF.DNS.SERVER
To force proxy resolver on the Mikrotik itself:
/ip dns set allow-remote-requests=yes
/ip firewall nat add chain=dstnat protocol=udp dst-port=53 action=redirect
-----> be sure that your input chain blocks new DNS connecions incoming on the WAN interface. Test this with http://openresolver.com/
EDIT: if enforcing that DNS queries go to some internal host, be sure that the internal host itself is exempted from the above rules with an accept rule for DNS traffic from its/their IP address(es).
Hi, thanks for the assist, but it doesn’t work!
make sure these block rules / nat rules appear in the right order in your chains.
If you added the block rule, for instance, and this rule comes after a rule that allows all traffic outbound on the WAN interface, then the block rule is never going to be reached.
add this to the rule
place-before=0
Hi, have realized that it has blocked only wireless connection, but LAN is still through!?
ZeroByte,
hey, that really worked thanks a lot men, now i still need your help, nowadays my ISP is redirecting accounts to quarantine if they find out that your dns traffic is high
any solution to avoid quarantine?
Thanks.
If you force the local users to use the Mikrotik as their resolver, then the Mikrotik will cache most lookups so any burst of traffic will only get cached replies and not send them to the ISP.
chain=dstnat protocol=udp dst-port=53 in-interface=LAN action=redirect
chain=dstnat protocol=tcp dst-port=53 in-interface=LAN action=redirect
chain=dstnat protocol=udp dst-port=53 in-interface=WLAN action=redirect
chain=dstnat protocol=tcp dst-port=53 in-interface=WLAN action=redirect
Also, set RP Filter to strict in /IP Settings so that if a LAN workstation is a member of a botnet, spoofed-source DNS queries will not be answered.
Hi Byte,
i have done that but all the machines loses internet.
chain=dstnat protocol=tcp dst-port=53 in-interface=WLAN action=redirectAlso, set RP Filter to strict in /IP Settings so that if a LAN workstation is a member of a botnet, spoofed-source DNS queries will not be answered.
You must have DNS servers configured for the Mikrotik itself in /ip dns
You must also enable “allow remote requests” in order for this redirection to work.
Of course make sure that the WAN interfaces will block DNS queries
You can test your configuration by entering your public IP address into this test site:
